zjmech17
- pennsylvania
I'd apologize and chalk it up to having a tard day, you are likely to need Mike again way before he needs you. Bring rude isn't likely to be productive in the long run. Mike is a problem solver and pretty good at it. he has helped me on numerous occasions and saved me many hours of troubleshooting a problem he has already solved.
I have both, the closed and the open system. Either, well maintained, is marginally acceptable. Some of us get a kick out of making the closed system work, when it works it works well. Both systems have high spots that trap air.
I learned a long time ago, even the dumbest guy in the room is going to have good idea sooner or later and the only really dumb one is the the one who refuses to listen.
I do pretty well troubleshooting electrical systems (over fifty years of practice), most would make an XJ look like a toaster. Mike has helped me out and steered me in the right direction many times. It took a team of engineers to engineer the XJ, hard for one guy to know everything. I've also found it smart to learn from the others guys mistakes, a lot less painful (expensive) in the long run.
New isn't necessarily better, I've had a lot of new parts fail quickly or perform poorly. Even OEM parts in many cases aren't what they used to be.
Fine I apologize but the fact of the matter is I asked for help with a problem. I didn't ask for people to make comments that don't pertain to the question at hand. I'm asking to see if people.had any similar issues. Not tell me how "great" the system works. I could careless. I'm sorry butnim not gunna chalk it up to anything. I'm getting anoyyed at the lack of peoples common sense. I asked a question. If you have info on it share if not dont comment. Thank.you
