GroversXJ
- Peoples Republik of Kalifornia
I am in the middle of converting my cherokee to use R134 from its original R12 system. I replaced all the o-rings with new ones as well as replaced the dryer/filter as well as the expansion valve with new pieces. I have already put in the correct oil. I was trying to evacuate the system and realized the low pressure port is too small for my R12 gauge hose to connect up. So was there an even smaller R12 connector used on renix systems or is there a special adapter I need to get?
Here is a pic of the low pressure port on my compressor (bottom) and a brass fitting that is the same configuration as the high pressure port on the compressor (top).
