$5000
114k miles
Manual trans
electric door locks/windows
AFR 185 heads
performer rpm 2 intake
comp cam 1.6 roller rockers
BBK 75 throttle body
75mm throttle body spacer
Pro M 42 lbs 75 MM MAF
42 LBS injectors
ford motor sport E-Cam
MSD ignition
MSD Coil
Ford racing valve covers
Moroso cold air intake
electric fan
Smoked headlights
140 amp pa performance alternator
Boss pro cowl hood
Hurst short throw shifter.
literally 5 miles on new clutch and cable.
Roll bar
Flow master exhaust
BBK headers
H-pipe
Sub-frame connectors
Line lock installed but not wired.
new brakes
new battery
new tires
Alpine stereo with amp and 10" subs.
The bad:
Paint
114k miles
Manual trans
AFR 185 heads
42 LBS injectors
MSD ignition
MSD Coil
electric fan
Smoked headlights
Boss pro cowl hood
Roll bar
Flow master exhaust
BBK headers
H-pipe
new brakes
new battery
new tires
The bad:
Paint
