Sandbar
- North GA Mtns
Parts swapped without doing my homework. Cousin had an 89 headed for the scrapyard with good D30 front hubs, both on my 92 were shot. Pulled his, noticed they were shaped a bit differently but fit right into place. Bolted everything up, and now it seems the brakes are locked tight. Will move barely in low range. Are 89 hub bearings not compatible with 92, or should I check something else? Thanks!
