remove the fuel pump, I had a very similar problem and it ended up being the fuel line between the pump and the sender, it was not holding the pressure......
I know for certain that I am not getting spark most of the time. When I would crank it over to try to start it the tailpipe smelled like gas, and whenever I poke the Schrader valve in my fuel rail gas squirts like old faithful. I don't think that is the problem, when I can get spark every time I will move on to fuel systems.
I asked this question back in post #13
Do you have 12 volts to the ignition wire at the 3 prong plug and do you have a tach signal from the other plug?
When you have the no spark situation (verified with checker) is there 12 volts there?
Today when I tried to check I did not have enough battery voltage to crank over, but I was able to get the same voltage at the 3-prong connector. The battery is on charge now so I can really test it. I think all this charging and discharging has finally taken a toll on my battery. Can I measure my tach signal with a multi meter?
Intermittent spark.
Coil. Coil to ICM clips. ICM. B Latch relay. ECU. Crank sensor. Harness between any of the aforementioned.
Note: there are numerous grounds to the DIPSTICK tube--ICM, ECU, o2 sensor and others. Make sure to strip things down to bare metal, treat with an anti-corrosive agent, and make the connections TIGHT.
Note: there is a POS braided strap from the rear of the head to the firewall. It is the one and only XJ unibody ground on the early rigs. Replace the strap with a 4 or 2 ga cable, strip down to bare metal, treat with an anti-corrosive, and make the connection TIGHT.
Good luck.
Coil is new, coil to icm clip things were cleaned with electric contact cleaner, and then smeared with dielectric grease. Icm is new; connectors were cleaned with electric contact cleaner, then smeared with dielectric grease. Ecu is new. crank sensor is new. I checked the harness for continuity it said it was fine but nowadays I’m second-guessing everything. I took apart every connector I found (that wasn’t obviously to the lights or anything) and sprayed it liberally with electric contact cleaner, then smeared with dielectric grease
What is a B latch relay? I don’t think I have replaced that.
Dipstick grounds were moved one threaded hole over because that hole was stripped out, but it was wire brushed, cleaned with electric contact cleaner, then smeared with dielectric grease.
I added one more battery ground to the fender.
I left the pos braided strap in place, but supplemented it with another ground, cleaned with electric contact cleaner, then smeared with dielectric grease. Both of my new grounds have thicker wire than my battery cables haha.
There is a common problem with the C101 connector above the brake booster. Jeep recommended cutting it out and wiring direct.
I found this advice from the first page I forgot to implement! I will give this a go too, I forgot about it. :dunce:
Thanks again for this great help!
