84-01 Cherokee XJ-4.5" Short Arm Flex System 999$ With Free shipping
RWKHausSupply
$999 shipped to your door!
RKXJ45SAFS
See this deal here
The Rock Krawler 4.5 Short Arm Flex System comes complete with everything you need to fit 32 Inch tires underneath your XJ. This system uses double adjustable/high misalignment front lower control arms and an adjustable/high misalignment front track bar made from solid alloy steel. No weak tubing to bend or break for the ultimate in performance and durability. Adjustable front sway bar disconnects with long travel stainless steel brake lines are included to enhance the off road ability. The rear utilizes a 2" full length add a leaf to help control greater unsprung weights and help out tired old leaf springs. To complete the lift in the rear a rugged 2" billet aluminum block and u bolt package does the rest. This system is simply the best value short arm system for XJ's on the market and comes with our exclusive abuse proof lifetime guarantee on all hard parts!
System Benefits:
-Complete Bolt in System
-Excellent Highway Ride and Handling
-Allows for 32 Inch Tires
-Limited Lifetime Warranty
-Upgradeable to long arm system
System Includes:
2 linear long travel front springs, 2 full length add a leafs, 2 front high misalignment/double adjustable lower control arms made from 1.625" solid alloy steel, a high misalignment/adjustable front track bar made from solid alloy steel, front track bar bracket made from 1/4" thick laser cut steel, front adjustable sway bar disconnects, 2" rear blocks, long travel stainless steel brake lines front and rear, u bolts, hardware and detailed instructions.
*Requires a transfer case drop kit, or a C.V. Driveshaft Conversion, or a SYE with C.V. Driveshaft Conversion
**May require minor front fender trimming to run 32 Inch tires.
***Actual lift height in rear may very depending on condition of OEM leaf springs.
BY ORDERING THRU RWK HAUS SUPPLY YOU WILL GET THE NEW KRAWLER JOINTS!
Recommended Accessories:
- Transfer Case Drop Kit - $20.00
- Rock Krawler X Factor Plus Steering - $399.00
- Rock Krawler Adjustable Weld In Poly Foam Bump Stops - $115 per pair.
Shock Notes:
It is recommended that high quality shocks be used with all Rock Krawler Suspension Systems.
Front Shock - 17" Collapsed to 29" Extended
Rear Shock - 16" Collapsed to 26" Extended
This is a Great kit with the best control arm joints on the market currently. And all arms are Solid steel. Lifetime warranty on all hard parts.
worth every penny...
why not get the better kit for the same price.
Rock Krawler:
Solid arms
better joints
better warranty
To the Top
