- Foresthill, CA
Bradlybob said:So let me get this straight. Pull the diff from the housing, pull the pinion, clean it up good, install new crush sleave, install pinion, install new seal, silicone splines, install yoke, tighten pinion nut in incriments to specified torque, check preload with diff out, tighten pinion nut until proper preload, install diff, fill it back up and go.
Thanks all.
Perfect!
