themangeraaad
- Halifax, MA
So I have been searching around and doing a bit of research on a D44/9" swap from a late 70's bronco or F150. I plan on running 36" tires by the time all is said and done, so I need something a bit stronger that the stock stuff.
So I have found that the stock axles are approx 60.5" WMS to WMS (I have also heard 58", but I don't know if that was the WMS width). I have found that the '78/'79 F150/Bronco had the HP D44 front and 9" rear that were approx 66" WMS to WMS. Can anyone confirm these numbers?
Also, I have read that a same year F250 has the HP D44 front (heavy duty in some?) and D60 rear, but they are "a bit wider" than the F150 axles. So I know they are a bit wider.. but I couldn't find any actual numbers, particularly WMS-WMS numbers. Anyone know this info? If "a bit wider" means approx 1" wms-wms wider, I may be able to live with that. If it means 2" + wider I may run into issues. Erm.. well I will probably be running into issues either way, but I will cross that bridge when I get there :roflmao:
Long story short I was going to pick up a D44/9" out of a F150, but I just came across a D44/D60 out of a F250 for sale locally. Granted I know there are different things to take into consideration (lug pattern, overall size, strength, etc) but I am ignoring those for the time being and for now just want to compare axle width. I will get to the other aspects of the axles once I know what I am working with.
This is mainly because I currently have stock axles and 33x12.50s that are backspaced so they stick out approx 5" on either side of the rig. I have seen a build where someone threw full width axles (I want to say it was an F150 D44) under their XJ. With "normal" backspacing the tires only seemed to stick out a bit more than mine do now.. I am beginning to think with the correct planning/wheels, I may be able to avoid shortening the full widths and stay relatively close to my current width (a good thing :thumbup. For 36" tires & selectable lockers, either axle setup should be strong enough... so it is starting to come down to width and availability. Either way I will need new wheels, new driveshafts (or adapters), and other such parts. So those costs balance out.
That and having the HD D44/D60 combo would be badass, even if it's just for the bragging rights Thanks for any help!
