I would highly recommend avoiding any synthetic oils in differentials as does the very well known axle shop I work at
The reason is because even the thicker weight oils are much thinner than their conventional counterparts, and not only doesn't provide good cushioning for the gears, it doesn't stick to oil slingers and bearings as well causing lubrication issues over time.
Even if you don't notice any noise right away, damage is being done.
