Smittty9785
- SE Portland Oregon
ok 4wd is not working properly. it works somewhat when it is cold and when it is not cold everything is fucked up. if it is warm like at 210 or so and i try to put it in 4lo then it will just die, i have to put it back in 2wd to start it back up or will will just die again. and when i do restart it it jumps to like 3k rpm then slowly goes down to 1500 in drive, if it is in neutral or park it idles around 2k rpm. and if i am on the freeway and hit a bump then it jumps idle i guess. and if i hit the gay it hesitates like it wants to go but then it just spudders, and i have cheked my vaccumn lines and all are in tact. what else would it be?
