Noticed I had a coolant leak...looked like the thermo, replaced it, no prob. Get MJ running again, water pump was the leaky culprit, just along the very top edge...not too bad will replace it later.
Noticed that my thermostat opens up when engine temp reaches 220. Idles just above 210, but when driving (sustained 30 to 80 mph) the temp stays just below 220. I seem to remember it hovering just above 210 and never getting even close to 220.
I believe I replaced the thermo with a 190 or 195 degree thermo...will the 5 degree diff in the thermos cause a higher running temp?
What temp does your 4 banger run at?
