mecompco
- Fairfield Maine
33s with 4.56s is pretty comfortable, but if I had a chance to do it over, I'd go 4.88. As the Jeep has gotten heavier, the loss of performance has become more noticeable.
BADaXJ said:one thing to keep in mind is that the AX-15 is geared lower than the AW4. i'm running 4.56's with 33's and an AX-15 and i love it. first is real low and its fun to drive, plenty of pickup. it's nice because i can pass in 5th without having to shift down. i have done a bit of highway driving with this setup and wouldnt want to go much lower. just to give you an idea... i have rear disc brakes and when i had my front ds pulled i was playing around in low. i took my foot off the gas pedal and hit the brakes. the jeep stopped rolling and the rear tires just dug into the hard pack dirt. i never hit the gas and the rear tires just kept turning at idle . it's geared pretty low but obviously lower is better for wheeling. having said that, i'm very happy with my combo for daily driving and wheeling.
BADaXJ said:i was just saying that two rigs, one with an auto and one with a manual, would have different characteristics(obviously). but from what i've seen, the AX-15 with one step higher gearing is usually comparable to an AW4 equipped rig. and torque converters also generate a significant amount of heat...
BADaXJ said:regardless of the opinion that auto is better than manual... the gearing is different enough for it to matter. i've driven both and the ax-15 with the same gears seems lower. thats why they came stock with 3.07's and the AW4's came with 3.55's...
XBoBJ said:what would you recomend for a 99 5spd xj DD im going 4.10s 33's will that be bad?? im doing 4.10s because i can do it for 450.00 total....
