knever3
- Midland Mi
I have a 4.7L stroker motor that I will be installing in my '87 Jeep Comanche. Specs are '96 block and head, '99 intake with 62mm aluminum throttle body. I will be using the renix system to control it.
Questions.
What do I need to properly keep an eye on the motor other than standard gauges?
Adjustable MAP sensor?
Wideband air fuel ratio gauge?
I have been searching the internet but can't find what I am looking for without talking to someone that has a similar setup.
I want to know if it's running right not guess, any suggestions built on experience wanted.
Thanks!!
Questions.
Thanks!!
