1989 ( RENIX JEEP ), Cherokee, 4.0 L, 2WD, about 140,000 miles (about 30,000 miles since head gasket was replaced, with head cleaned, and new seals, plugs, wires....the works).
ASM Test
......................25 mph, 1605 RPM ................................15 MPH, 1670 RPM
.....................LIMIT................ RESULT ....................LIMIT ....................RESULT
HC (ppm) ..........179.................... 97........................ 183..................... 131
CO % ................2.22................ 0.74 ........................1.65 .....................0.97
CO2 % .....................................13.9 ....................................................13.6
O2% ..........................................3 ......................................................0.6
NOx (ppm) ........1161 ..................998 ..........................1262 ..................1246
Dilution % ..................................14.6 ...................................................14.6
1987 ( RENIX JEEP ), Wagoneer, 4.0 L, 4WD, about 278,000 miles. CAT is about 2 years old, 20,000 miles.
ASM Test
................high speed 25 mph, 1605 RPM ................................. LOW SPEED 15 MPH, 1670 RPM
....................LIMIT ........RESULT.......................................... LIMIT ................RESULT
HC (ppm) .......137 ............53 ...............................................140 ....................87
CO % ............0.87 ...........0.27 .............................................0.79 ...................0.41
CO2 % ............................14.6 .........................................................................14.4
O2% ................................0.1 .......................................................................0.2
NOx (ppm) ......956 ...........808 .............................................1046 .................. 1045
dILUTION % .....................14.9 ..........................................................................14.8
Both tested at the same test location, same test machine, only 3 weeks apart!!!!!
Running 20W50 API SL, Dyno oil in both, Citgo Regular gas.
