FlexJ17
- rancho cucamonga CA
Purchased a reman stock 4.0l long block from a reputable source at the beginning of this year. Had a shop install it, 500 miles later the camshaft+ lifters took a shit (when i removed them you can clearly see damage to the lifters and camshaft lobes) so i replaced them with a stock melling camshaft+lifter set within 100 miles i was getting a rotational knocking noise on acceleration inbetween 2500-3000 rpms, so i took that camshaft+lifters out and i didnt see any visible damage to either like the first set i took out, regardless i bought another new oem camshaft+lifter set, made sure eevrything was lubed up correctly and used joe gibbs break in oil, then after the initial 20 min break in i changed the oil to joe gibbs hr oil. I am about 300 miles into the 500 mile oil change and it has developed the same tapping inbetween 2500-3000 rpms, jeep runs good besides the noise at this point im thinking its something other than the cam+lifters but i have no clue. The tapping is kinda silent but its definitely there.
