-$3800- 1991 XJ. 6.5in longarms, 35'' tires. NV3550 transmission, ford 8.8 4:10 gear
sh!nny
Littleton CO
Means of contact: pm
Price: $3800.00 OBO!
Wutsup NAXJA repostin my XJ.
Selling my 1991 Jeep cherokee Laredo.
-Rough Country Long arms
-Rough country 6.5in lift kit.
-Rubicon Express Track bar
-Front Pads, Calipers, Rotors, ALL changed bout 4 months ago.
-Rear Pads were changed about 8 months ago.
-Just put new NGK spark plugs, Denso Wires, Dist. cap, and Oil change TODAY. 1-28-2012...
-Ford 8.8 Rear end with LSD
-has Stainless braided brake lines and brake fluid flush was just done recently.
-PSC power steering pump, and power steering cooler
-D30 front with Spicer U joints, and brand new Timken wheel bearings changed 4 months ago
-Both front and rear diff fluids changed 5 months ago with Redline synthetic 85-90
-Gregory's Machine shop front and rear Drive shafts with upgraded U joints
-Custom Rear bumper with 2 D-ring spots and a hitch reciever
-modified front bumper painted black
-rockers, undercoated and rear rocker panels were folded up for clearance and also undercoated
-Whole interior is bedlined with line-x
-NV3550 Jeep Wrangler TJ transmission
-B&M short shifter kit
-Novak transfer case shifter
-4:10 gears in the diffs
-Np231 transfer case
-both brand new headlights
-wooden steering wheel
-RC Transfer case skid
-Rusty's Tie rods with HD moog tie rod ends
-Slip yoke eliminator
-1995 Jeep grand cherokee bottom end (has girdle)
-1995 Jeep Cherokee Head
-35x12.50 Mickey Thompson MTZ baja's
-Brand new water pump, serp belt and tensioner changed 4 months ago
-NO RUST AT ALL.
The Bad
-leaks a LITTLE bit of oil from Oil filter housing O-rings (very easy fix, not even enough leaking to have to even add oil in between oil changes. and oil is changed every 3000 miles with castrol syntec 10w30 and chrysler oil filter)
-transfer case has a very slight leak
The clearcoat is non existent lol
-interior isnt minty.. (mud stains and whatnot. no carpet... etc... what do u expect?)
-front tires have some cupping and road noise.. i would say there at about 50% tread (what do u expect?)
-rear tires have about 60% tread life. no major cupping
-Gas guage and oil press. guage dont work in cluster. but i do have a gas guage and oil press. guage on the A pillar that work fine.
-once every so often. (happens maybe once or twice every 2 weeks, it wil kind of sputter but only happens for like a second and acts normal again...
-second fan isnt hooked up yet but will come with the jeep.
-e brake cables broke off wheelin
ROOFRACK PICTURED IS NOT INCLUDED.
Previous Owner can vouch for all the work done as well.
I know i am probably missing a lot of stuff, but this is the jist of it so far. i am sure ill see more things ive mised and will post them up later!
before i painted the rockers and rolled up the rear rocker panel
The spare is not included
ill get more pics tomorow in the day time.
*jeep is sold as is. in Maryland, it qualifes for historic tags. I have them on there now. No inspection, No emmissions, AND NO HASSLE FROM POLICE. also my insurance is 18$ / month lol...
there is A LOT OF MONEY int his jeep. dont let the outward appearance trick you.. why pretty up something on the outside that is going to get bent up?
this thing is a monster on trails and runs awesome.
