mindless
- West Seneca NY
Spend $100 and get yourself another 2" of lift with shackles and spacers.
Spend $100 on a hack and tap SYE
Trim your fenders (free)
Might need new shocks? Depends on what size lift yours are rated for.
Spend $100 and get adjustable track bar
If you don't already have new lower control arms, spend $150 and get new ones
Get some YJ brake lines (free at a jy or can't be that much at a parts store), good for about 5" of lift.
Gears would certainly be good if it's a DD. You can go fine without them, your jeep will just be more of a dog than it normally is. If you do the gears you're looking at anywhere from $400 (if you buy used axles already geared) to $1500 (having a shop regear both axles).
So, realistically, you can get away with the 35's for $300 or so up to $2,000. Depends on what you want/need.
Looks good only thing i would say is drop brackets for the control arms would be a great add on over adjustable lower arms.
