97 XJ 1,2, and 4 work fine 3 has no fan operation. I'm thinking blower motor resistor and the manual has a test procedure but isn't real clear on where it's at other than under a "kick panel"
You're in better shape than me then. Mine only works on "4". I haven't gotten around to pulling the resistor block out. I priced the entire block at orielly's and the stealership, both wanted around $40. I've been told, but haven't verified it yet, that you can desolder the resistors from the block and just replace them with equivalents from radioshack.
Fixed mine today. New part with lifetime warranty was $50 at orielly's. I haven't looked the old block over very well, but the first thing I thought of when I saw those coils was winding my own e-cig coils. I suspect they can be replaced as well if you found the right size resistance wire.
The entire resistor block(white thing in Tim_MN's picture). You'll have to remove the glove box to get to a couple of the screws on the plastic trim that covers the blower motor housing. Half hour job.
As soon as I have some free time I'll look at the old resistor block and figure out if the bad component is a resistor or a thermal fuse. Either way, I'll replace it and have a spare block on hand to throw in for the next time it fails.
