RockTracXJ
- Colorado Springs
Up for sale is 3 Hella FF200 fog lights. These bad boys are pretty sweet and are in great shape. Includes the stone shields and mounting hardware. $100 + shipping
"Hella’s powerful Free Form Reflectors employ computer-aided design to deliver a precise beam pattern, producing up to three times more illumination than ordinary lights. The FF200 Series Fog Light gives you big light performance in a small size.
The Hella FF200 Series Fog Light uses a halogen bulb that distributes its light with a powerful Free Form Reflector mounted behind a clear round lens (just under 6" in diameter). The lens is bonded to a high-impact ABS housing that provides a rugged construction for performance and durability. This auxiliary fog lamp assembly uses Hella’s Fast-Fit system for quick and easy, upright or inverted mounting on molded bumpers, air dams, brush guards, in the grill, or on or under the bumper. Hella’s Fast-Fit mounts with a single nut and bolt or two molly bolts for tight spots or limited access areas."
