Based on the latest info here the dying with throttle applied, acceleration, is a dead give away that the TPS, or its connections, or wiring are bad. Replace the TPS, they do wear out!
Also check the MAP sensor to throttle body vacuum line and make sure it is not loose. I still think the dying when it warms up is one of the temperature sensors, coolant or Air Intake Temp sensor.
If the injectors were bad it would not idle properly at all. CTS and IAT affect the electronic timing, adjusting the timing for hotter engine and intake air as it warms up, and adjusting the A/F based on the changing air density.
