I have quite a bit of stuff I've accumulated that I'd like to get rid of,
I have a 242 with a Tom Wood SYE. This T-case is a late model but has a different tail housing than most. Back when I bought the SYE I had big problems with leaks (common for the late model SYE I believe). Tom came up with the idea of going to an earlier style tail housing, which has two seals on the output. Ever since that change the output has not leaked. $350
Hidden Hitch receiver hitch in good condition. These are nice because it is tucked up very close to the stock bumper and doesn't reduce departure angle. $40
I have pretty much an entire grey interior from a 2000,
Front and rear seats, DS seat has a burn hole in the seat bottom
All interior trim including door panels
Carpet that I cleaned and it looks very nice, few if any stains
I have the headliner, if someone is interested I'll have to look at it again to
see what kind of shape it is in. I'm pretty sure it is in very nice shape
Dash parts including most under dash parts
I have 3 of the power window motors, I sold one of the fronts, I believe the PS, If you need one I'll check what I have
Most if not all interior switches
I think I also saved the headlight bezels, white
For all of the interior parts we can discuss prices based on what you all want. Of course shipping to FF is free!
It looks as though I will have a short arm RE kit to sell also. Lower fixed arms, upper adjustable, and drop brackets. The drop bracket reinforcement stiffeners may or may not be available (I welded them to my frame so unless I can cut them off without wrecking them they will not be available). The joints and bushings are pretty well used and may or may not need to be replaced (bushings) or rebuilt (joints). There is no track bar with this, just the arms, brackets, and possibly the reinforcement brackets.
B-loose
B-loose
