- WA state
He was talking about the locker, not t-case.selectable. it has part time 4wd. 2wd. 4lo and 4hi
Another vote for keeping the 242.
x2 on the Tom Wood. A little pricey, but well worth it in my opinion. Kind of surprised you need a SYE at this point. I ran a 5.5" lift with a .75" TC drop (essentially lifting the TC 4.75") for 6 years before finally getting a SYE. Vibes were hardly noticeable and I never wore out any driveline parts. Maybe it's a pre '97 vs. post '97 thing... I was under the impression that the older XJ's had less problems in this arena though?
I decided to do the SYE when I upgraded the rear end to a D44 so I'd only have to buy a new driveshaft once. Something to consider if you're planning on getting rid of the D35.
here is the simple decision branch: if you want to use the jeep for all-wheel drive on slick surfaces (ice, rain, mud) then the 242 is going to be your best bet. if you want to use the jeep for four-wheel drive on loose surfaces (gravel, dirt, mud) then either will work but the 231 will work better.
Other than the 231 being Marginally stronger than the 242, Why would the 231 be better than a 242 off road?
When you shift the 242 into part time what's differennt from the 231?
the aftermarket support makes it a better choice for off-road useOther than the 231 being Marginally stronger than the 242, Why would the 231 be better than a 242 off road?
HD panetaries,HD chains,HD output shafts,2Low kits and 4:1 kits!
The problem with the 242 is that is uses a viscous coupler that tranfers power to the front or rear as needed in full-time 4wd. This is what makes it so good on slick roads. This is also what makes it so bad for lockers, at least in full-time 4wd. Just like an open diff. which tranfers power to the tire with the least resistance, the viscous coupler does the same thing on slick roads but on rocks will sometimes stop sending any power to a locked up front or rear end just when you need the traction most. I understand that part-time is different but some 242's are full-time only. The viscous coupler is also prone to wear that will manifest itself by the tires grabbing and jerking when turning in 2wd as if you were in 4wd.
I'm not saying that it's a bad t-case. It's great for slick roads and such but if you plan on rock crawling the 231 has a much better aftermaket parts selection and is more suitible for lockers.
Just my .02
Cheers!
I was talking about whats available for the 231.Now are you talking Stock 242 Vs 231 or aftermarket?
Does a stock 242 have stronger internals than a stock 231?
Thats correct,no VC in the 242.i believe that the 242 doesn't have a VC...the 249 does...
Just my .02
Cheers!
You're describing the 249, which came in Grand Cherokees, not XJs. The 242 does not have the viscous coupler.
