2001 XJ FS
bobnoxious
Marion, MA
For Sale: 2001 Jeep Cherokee (XJ), 225,000 miles (over geared for tire size, see pic), head rebuild (with all new valves) at 200,000, new alternator and tensioner pulley, Flowmaster muffler with OEM Cat and full exhaust in place (no Ricky Racer bullshit here).
Power windows and locks, AC, Alpine stereo (professional install), remote start (professional install.
-HP D30 front with 4.56 gearing, ARB, Alloy shafts, tube seals, Rock Crusher diff cover, 5x5.5 Lockout Hub Conversion
-D44 rear with 4.56 gearing, ARB, Alloy shafts, Rock Crusher Diff cover, Teraflex Disc Brake Conversion (new Calipers and pads and parking brake shoes)
-4.5" lift with TNT Long Arms, Clayton HD Track Bar and Drop Bracket, Drop Pitman Arm, Rusty's Tie Rod Assy, JKS sway bar discos, TNT U-Bolt Eliminators in rear
-Custom front winch bumper built off a Detours Backbone (with steering box reinforcement), Warn M8 winch
-Detours Slim Line rear bumper, comes with swing out tire carrier (pivot pin has broken, needs repair)
-33x10.50x15 BFG MT/KM tires at about 50%, mounted on early Samurai rims
-SYE with front shaft in rear
Headliner starting to sag, AC needs recharge, rear main seal leaks some, rear pinion seal leaks some.
$5800 Marion, MA
