winterbeater
- Royal Oak, Michigan
Are you saying that your 2000 Xj has a distributor? i.e a true distributor with 6 ignition wires coming off it?
Moro's is an '89, Chris's is a 2000.:idea:
Temp sensor would not likely do that, and it seems unlikely if the engine was running fine before, although it could theoretically go bad and make the engine run really rich. You can pull a plug and see if its soaked.
Sounds more like the CPS though
This is not the common heat soak issue for the following reasons:
1) The heat soak issue is only when you start your engine, not when it has already been running.
2) That silver heat shield has nothing to do with heat soak. It is part of the TSB to prevent garbage gathering in there and starting a fire
3) The TSB for the heat soak issue puts an insulator on the #3 injector.
Now that that is clear up.. about what is the engine temp when this happens? Did it just hit that temp, or has it been there a while.. perhaps it has something to do with the PCM switching from open to closed loop.
Did you ever determine yet, if it's the spark or the gas that's missing when it won't run?
I had the exact same issue with my 96 XJ (would crank but not start when hot, and would stall out when stopped). Then the CEL came on.
I disconected the battery for an hour to clear memory, and that fixed the problem. Have you had your battery disconnected for at least 30 minutes since all of these issues began? It is definately worth a shot.
Side note: This issue has occured twice since I have owned my Jeep, both times after I was tinkering under the hood and have disconnected/connected electrical connectors. I knew both times that I had not broken anything so I reset the ECU by removing power for an hour. This was a tip I learned from my autoshop teacher in High Scool. When all else fails, reboot!
Did you ever get the cam shaft sensor adjusted correctly using the tooth pick method?
Could the CKP to flywheel spacing be just a little to big? I wonder how thick that paper spacer is?
Wow! I'm not to sure I want to get into that. These are threaded holes and I wouldn't want to mess that up. I am going loosen up the bolts and see if there is any play in it at all. Then retorque everything to spec. If that doesn't work I'd like to take it out and compare it to a new one to see if the plate that the sensor is mounted to matches and as the sensor mounted in the same place. My thought is that it may be off just enough to be giving me all this grief after the engine warms up and everything get loose. All my problems started with this one little sensor and I did not install this sensor the last time, the shop did. This was the same shop that also started throwing parts at it when they couldn't figure out what was wrong. I'll keep you posted.So, if you pull the two bolts out and try pushing it down closer???????????? If it's not real close, you could file the holes open bigger.
