Miller88
- Syracuse NY
I'm really confused here.
I'm not sure what I am supposed to be seeing for voltage ... or what the connectors are supposed to do.
Can someone help me!
The window tries to go up (but it's already up). It won't go down, I don't hear the motor attempt to do anything to go down. I hear it try to go up.
To start - the switch has 5 wires to it
Yellow (12V Source)
Gray/Black -
Gray
Green/White
Green
On the DRIVERS SIDE they have the following values
Yellow- 12v
Gray/Black -.2v
Gray
Green/White .2v
Green
On the PASSENGER SIDE
Yellow- 12v
Gray/Black -.1v
Gray
Green/White 0v
Green
First thing I did was switch sides on the switch after verifying that they functioned the same. That was a no-go. It does not try to go down.
I ran a continuity check on these and found:
UP - Yellow is connected to Gray
Down - Yellow is collected to Green
This is the first thing that confuses me. What are the Green/White, Gray/Black wires for? The continuity check of the switch tells me that these don't do anything?
When I tried to put the switch both up and down ... I end up with POSITIVE voltage on both the solid Green and Gray. This I do not understand.
I wanted to juper from the solid yellow right to the regulator to make sure the regulator was not the problem. I can't jumper either side to make the window go up or down. So really confused now.
Help!?
Yellow (12V Source)
Gray/Black -
Gray
Green/White
Green
Yellow- 12v
Gray/Black -.2v
Gray
Green/White .2v
Green
Yellow- 12v
Gray/Black -.1v
Gray
Green/White 0v
Green
Help!?
