xjmania123 said:I just came across Rubicon Expresses 2" lift kit. Does anyone know much about these?
http://www.redrock4x4.com/shop/products/231.html
I actually like the rocky road plan for a 2" lift better than the re. Add a leafs and shocks. hmmmm. But, it does depend. Do you like the way you leafs are feeling now, or do you want to firm 'em up a bit? The add a leaf will stiffen your ride. And typically supple is good - stiff is bad.
The 1 1/2 inch shackle will put more stress on your leafs, that's why a 1" shackle and a 1" block would be worth considering. Rather than the 1 1/2" shackle and the 1/2" block.
Truth is, for a 2" lift, any of these setups will work fine. Just go for the best value, which is short blocks, shackles, and spacers. If you buy the re 1" shackle you'll probably have it forever. For example if you want to go higher someday and buy a whole new leaf pack you'll still use that shackle. No wasted money there.
31" tires will fit fine - no need to trim your fenders.
