- San Jose
Getting rid of a pair of mickey Thompson Baja mtz mud terrains on steel round holes (black rock brand steelies iirc). One wheel has the rock ring I welded on a set and the other is just a regular steelie. No need to worry about the wheel with the ring, I daily drove a set of these rock ring wheels and had no vibes.
Wheel with rock ring: 2017 tire, good tread left, 5x4.5 wheel with 4.25” BS. 8” wide. Balanced. 120$
Normal steel wheel: 2016 tire, good tread left, 5x4.5 wheel with 4.25” BS. 8” wide. Already balanced. 120$
Located in San Jose. Not running stock bolt pattern so no use for these anymore. Would make good trail spares for those of you on 33s, or even smaller wheels to pass smog,
If you want them both I’ll take $200.
