beakie
- Ontario, Canada
I've done a lot of reading lately regarding these engines, older/newer no matter what they are in, they seem to burn oil. VW says; 1L every 1000miles, 2-3L each oil change, upto 5L per oil change, depending where the info is coming from... mine said 2L was normal at first, now that I've moved upto 4L they say thats excessive but still within tolerable levels. Oil is changed, as per VW, every 16,000km's.
Tomorrow it goes in for its 80,000km oil change, and they will be doing an "oil consumption test" after it being brought in just over 1000km's ago. I have mentioned this problem 1/2 dozen times over the last 2+ years of owning it, and they are just now deciding to run this test, which is difficult for me to understand how they are performing... "oil consumption test" unless your draining it each time how can you tell consumption? even then how do you know it's out of each galley/channel/etc?
Anyway, other than the obvious oil burning I've noticed these symptoms aswell;
if I remove the oil fill cap it instantly changes idle, and
there is a large volume of air escaping from the hole.
this to me would be either a piston rings &/or valve seal problem.
Unfortunately I am dropping the car off before opening, going to work and will have to call in to talk to them.
Any ideas/experience/thoughts on what I can do/say to get this problem fixed sooner, rather than dealing with the run-around that I've read about so many people experiencing.
Thanks for any and all help.
