1999 Jeep Cherokee XJ sport. 78,XXX original miles. Supercharged 4.0 engine with AT transmission. Listed below is a lengthy list items installed within the last year. I started this build with a very nice low mileage rust free Jeep I had shipped from Arkansas. The original owners were an elderly couple that took care of the vehicle and never abused it. They owned the vehicle for all but 900 miles that the grandson that inherited the vehicle put on the Jeep before I purchased it. Has clean car fax that back up all the information. This is my daily driver and with a young child and possibly another in the near future it time for a larger vehicle. This is by far one of the nicest Jeep XJ’s you will find or see. I can assure you won’t find another like this for sale. The inside of this vehicle looks like a 2014. All parts are new with the exception of the fuel cell. This vehicle has never seen off road use. Everyone who rides in the vehicle is amazed, because It’s not your typical loud, loose feeling Jeep with rattles everywhere, it is very solid and tight driving Jeep. The pictures really don't do this Cherokee justice,it looks amazing in person. It does have some chips mostly on front from highway driving and a few dings. The most noticeable is a small dent on the passenger side fender which is in photos. Overall the paint isn’t bad for being 15 years old. My number is 209.416.8857 if you have any questions regarding this auction. If you notice small specks in the photos it's because my camera has a few small pieces of lint under the lens. Possible trade for a 4 door 4wd truck that is equal or higher value and I can pay the difference. Must be a newer vehicle with under 100k My number is (2o9) 416-8857 20k Firm Thanks for looking.
More Photos at http://s791.photobucket.com/user/sicmade13/library/1999%
Rear End
· Dana 44 from a 1987 Jeep XJ
· ARB locker
· 4.56 gears
· Superior Chromoly Axles
· WJ disk brake upgrade with functioning e-brake.
· 4.5 Leaf springs
· Shackle lift with shackle relocation kit
· Poly bushings
· BTF diff cover
Front End
· Factory high pinion Dana 30
· Detroit Locker
· 4.56 gears
· Rough country 6.5 long arm kit
· ACOS adjustable spacers
· Fox shocks
· Alloy axle free spinning hub kit
· Alloy Chromoly inner and outer Axles
· Alloy outer axle seal
· Alloy Chromoly ball joints
· Warn hubs
· JKS Track bar relocation bracket
· JKS sway bar relocation bracket
Steering
· Ruff stuff 1 ton steering with offset tierods
· .25 wall dom drag link and tie rod
· GM H1 steering gear box
· Wj power steering pump
· Terraflex high steer knuckle
Armor and Bumpers
· Smittybilt front bumper with optional bull bar
· Smittybilt rear bumper with swing out tire carrier and gas can
· Smittybilt sliders
· Smittybilt XRC8 winch with synthetic rope
· Rough country frame stiffeners (Not installed)
Electrical
· H4 head light conversion with harness upgrade
· 50in curved cree led light bar with Hooligan light bar mount
· 12 inch cree led bar on front bumper
· 4 80w pods on front bumper and rear tire carrier for side lighting
· ARB ckmta12 twin air compressor with bulk head for air hose. Inflates a 35” tire in 1 ½ minutes and capable of running air tools.
· Cobra CB radio
· Two yellow top optima batteries
· Modified BTF battery tray for addition of second battery
· Cd player BT capable and Arc audio speakers and tweeters
· Viper alarm with smart start and GPS tracking. You can monitor, start, unlock, track and set up notifications all from your smart phone. With fences and hot spots you can set up for any location. Just paid for a 1 year subscription last month.
Interior
· Corebu seats that were stripped down and recovered to match using factory vinyl materials
· Heated front seats
· Corebu double locking sliders
· Corebu 3 point harness (factory seatbelts included)
· Rear seat recovered to match using factory vinyl
· Head liner recovered
· Carpet was removed and professionally cleaned.
· Rugged ridge rubber floor mats (front, rear and cargo area)
Fuel
· Bosch injectors
· Genright aluminum fuel cell with steel skid plate
Engine
· 78,XXX original miles
· Rimmer side mount supercharger kit ( jeeps supercharges . com )
· New plugs wires cap and rotors
· Cold air intake routed through cowl with K&N filter
· 62 mm throttle body
· All original parts to convert back to naturally aspirated if desired or for specific state emissions
· Brown dog engine mounts with rubber bushings (Not installed)
Transfer case
· Fresh synthetic oil
· Terraflex extreme SYE kit
· Rough country skid plate
· Tom woods rear drive shaft
Wheels
· 5 AEV Real bead locks (DOT approved)
· 5 bfg AT ko tires equivalent to a 35 inch tire. 500 miles on 4. 0 miles on spare. Spare also had a spare hub for the trail. All tires have a lifetime warranty with Americas Tire Company.
