1999 F-350 7.3 Powerstroke
Mike1331
Folsom, CA
$16,500
Located in Colfax
Extended cab with 4 working doors
The truck runs perfect and has low mileage for the year, Currently at 193,005. And gets an amazing 23mpg's on the highway.
4x4 works great with the more desireable manual t-case shifter on the floor.
All windows and door locks work perfect
I'm willing to drive it up to 1000 miles for the right buyer.
- 4" lift with a track bar
- Procomp rear Traction Bars
- Air ride bags in the rear
- 35" cooper tires that are a year old and still under warranty with Americas Tire
- Cold Air intake From SB filters
- Full Magnaflow exhaust
- Brand new AC compressor with a fresh charge that blows cold
- I have an Edge extreme power programmer that comes with the truck but I run the truck on the stock setting
- Upgraded Tranny cooler that is extremely large
- Transmision rebuilt from Transgo at 150k
- All front Ball joints replaced last year, alignment done at the same time
- Engine and transmission fluid just changed out 200 miles ago
- Rear axle has a factory limited slip Front is the high pinion dana 60.
- Wired for a sub and amp but are not currently installed.
- Current Registration
This is a very solid truck, i've had a diesel mechanic look at it and they said its one of the nicer trucks that they've seen. It's a great work horse that looks and runs extremely clean.
Keywords-
diesel, deisel, desiel, power stroke, powerstroke, lifted, lift, mud, crawler, tow hitch, toyo, general, rubicon, dodge, chevy, f-250, f 250, f250, f350, f 350
