Talyn
- Radford, Communistwealth of Virginia
x2 see if you have voltage at the injector connectors now.
Why cant everyone make a post that contributes to a guys issue at hand and help resolve the issue with past experiences rather than haze him about how he checks things.
Of course he isnt knowledgeable about it...thats why he made this thread...to get someones help that might have experienced this problem before. Im new to Jeeps myself as this is my first one. Each vehicle has those certain things that go wrong with them no matter what and everyone knows how to fix it if they have been around them long enough.Lets see.. according to him he has spark, good compression, fuel, proper power to the fuel injectors and the fuel injectors are good.... maybe his test methods are wrong, or he isn't as knowledgeable about this sort of thing. As for compression, what did he change that this issue came about after? The head gasket, which if there was a problem could lead to poor compression. Ans he said that he has a rough idle 100% of the time... its most likely that the engine is having a slight misfire (which the computer may or may not report) then at times a complete misfire.
No one is hazing anyone, grow a thicker skin.
Thanks Bobby!
The plug in 6 seems to be very black at the tip, I have put in 2 sets of plugs and 2 sets of wires so i am very doubtful that they could both be bad in the same spot.
So be nice and help the guy out without being a doucher...just sayin
I cant help him other than tell him what Ive changed..Ive got a similar issue with mine and still haven't figured it out. But as soon as i swap out my ECM with the neighbors ill let him know if it fixed my issue or not.I am being nice, I am trying to help him, which you don't appear to be doing. The only person that is a "doucher" here is you.
Well, after getting a call from my mechanic I finally have some info(all Bad!!). He came out and ran another compression check-
Cyl 1 130
Cyl 2 130
Cyl 3 130
Cyl 4 0
Cyl 5 120
Cyl 6 60
Looks like it's time for a new Motor!!
Compression will not cause a random misfire...
