- MilkyWay Galaxy
It electrical not mechanical. So even when its running badly at idle it should stay steady. I had mine read the right pressure but would not hold the volume when I accelerated. Same exact symptoms black plugs popping in the intake. You may try and check the relay for the pump or the ballast resistor on the drivers fender two likely culprits
I would set a volt meter up to see if power to parts like the fuel pump are coming and going.
One thing no one has mentioned yet, is the 12 volts to heater in the O2 sensor. If it is not getting to the O2 sensor, it will work when real hot, but come and go when warm, with your exact symptoms.
