1964 Ford F100
redneck
Same story as the 95' XJ. I work overseas and have no time for another project. Im loosing the place where I have been keeping my toys so they've got to go. I know this isnt Cherokee related but, its got a 9" rear end! Buy the 9" rear end for your XJ and get a F100 for free! If thats not XJ related enough, let me know! I am currently out of country but am able to answer any questions you may have. I will be back in Phoenix in mid-February.
1964 Ford F100 SWB
68000ish miles (on the OD)
223 I6
2wd
3 speed on the column
This truck is a good runner. All original. Does not smoke. Tracks fine down the road. Great candidate for a restoration. Could be used as a daily driver with a little TLC.
• Texas truck.
• Rebuilt Gen 12v
• Have all trim
• Newer tires
• Needs radiator in the future, currently JB welded (small crack on top but still holding up fine)
• Minimal surface rust around driver’s side window
• No other rust, no holes
• Shift column internals need work. (2nd gear is fun to find.)
• Small fuel leak under cab (Few drops an hour, will replace fuel lines before sale after 16FEB)
• Mechanical clutch linkage needs adjustment. (will adjust before sale after 16FEB)
• Slight bend to front bumper
• FWD LH fender dented on bottom behind bumper, under headlight.
• Slight deflection on lower side of drivers door
• FWD RH fender dented just to the right of headlight
• LH bed side dented down the center from wheel well to tail light (trash can hit)
• Seat needs to be recovered
• AM radio inop
• Steering wheel plastic wrap cracked
• Windscreen has a few chips
• Makes a single “pop” noise when making tight turns (suspected worn bushings in front)
• Missing tail pipe after muffler
$5000 OBO
