Jasper911
- Louisville, KY.
My 96 4.0 had an annoying miss...but was reliably running . Took out the distributor this morning and took it back to Autozone after I noticed that the three wires had been pinched at the cap. And upon closer inspection, one of the wires had an actual cut. Probably some unwanted electricity dancing around in there causing the missfire. I made note of the position of the distributor and went for the replacement. However, after the weirdness at AZ, I might've put the distributor in 180 deg. off. I turned it around and tried it but still no go. I checked the plugs and they looked pretty fouled by gas.
I need to find TDC so I can confirm the distributor position is right and hope it will run then. I didn't see any reference marks on the crank pulley, but not sure what to look for since it probably won't have a bunch of timing marks.
Thanks and hope everyone is having a great weekend.:helpme:
