Step one, remove your watch
Step two, unplug the electric fan
Step three, remove the two bolts holding the electric fan in and lift it out.
Step four, right below the power steering pump is an idler pulley, 15MM bolt, loosen it about 4 turns
Step five, on the power steering pump bracket is a single bolt pointing at the thermostat housing. Unplug the temperature sensor and move it out the way.
Step six, put a ratchet on that single bolt and start turning it and the idler pulley will start to move. As it moves it will loosen.
Step seven, remove belt and if the drawing on the fan shroud is not there showing you the routing make a drawing BEFORE you remove it.
Step eight a, install new idler pulley you got BEFORE you started. Anti-seize on that idler pulley bolt too.
Step eight b, install new belt
Step nine, start to tighten the serpentine belt with that adjuster bolt. A new belt need to be adjusted to 190lbs, use your Krikit II belt tension gauge you got at NAPA before you started
Step ten, reinstall electric fan and plug it back in. Put your watch back on.
Done. :laugh3: :laugh3: :wave:
