Old May 8th, 2007, 14:23
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
1988 Renix Coil Question
On the bottom of the coil block there are 3 places for 3 connectors to go into. On mine there are only the front 2 connectors connected. The rear one is disconnected and I havent been able to see it annywhere. Does anyone know if this is normal or if something is missing. I'm at work now and I'll get some pics of what i'm talking about up tomorrow.
Old May 8th, 2007, 14:30
Hellbent's Avatar
Hellbent Hellbent is offline
Re: 1988 Renix Coil Question
that's pretty funny....i just noticed that same thing about my '88 last week. mine's a 5-speed, i don't know if that makes a difference, but it's the same way. i looked at an '89 5-speed at work the other day and it was the same also, nothing in that "extra" position.
Old May 8th, 2007, 14:53
mccastlej's Avatar
mccastlej mccastlej is offline
There's not supposed to be anything there. If you take your coil off, you can see that there are no pins in that connector at all.
Old May 8th, 2007, 15:02
5-90's Avatar
5-90 5-90 is offline
Correct - there are only two connectors in three sockets on every RENIX rig I've got. This is normal, but I'm not certain why...
Old May 8th, 2007, 15:11
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Renix was just funny like that.
Like how five speed Renix rigs have teh wiring loom for the auto trans. TPS input just lying there hanging out doing nothing...
President & SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old May 8th, 2007, 15:15
5-90's Avatar
Yep - got two of those as well. There's probably a plug for the TCU underdash as well - I haven't gotten that far yet...
Old May 9th, 2007, 07:06
They probably just did it to cut costs on making and supplying 2 different wiring harnesses. I had a 2000 Taurus that had a lot of that going on in it.
1 more thing, does anyone make a performance coil for the 4.0L kinda like the Accel coil I have on my 2.8L
Thanks for the replies
Old May 9th, 2007, 08:25
GSequoia's Avatar
The ignition system is already strong enough as it is.
Us normal people...
Old May 9th, 2007, 11:54
How many volts per chage does it put out. I doubt that I could run anything larger than a 45 gap.
Old May 9th, 2007, 12:08
5-90's Avatar
Unless you're looking to run boost, most "modern" ignition systems (since GM put out their HEI in 1974 or so, and most followed suit before 1980) run plenty of spark. RENIX strokers seem to do well, based upon reports from the field (I haven't built one myself. Yet. I have done several Chevvy strokers tho, so the principles are not foreign to me...)
If you're looking for more performance, an ignition alone will give negligible effect on an electronically-controlled vehicle. You're going to have to do some work on the engine itself...
Old May 9th, 2007, 19:19
ah ok just hoping for a cheap upgrade Thx.
Old May 9th, 2007, 19:45
5-90's Avatar
As I explained it to my two boys - "Speed is a question of money. How fast can you afford to go?"
Old May 9th, 2007, 20:02
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
They all have the same harness. That way, they only need to tell the people in the sweat shop how to make it one way
How do you test a renix coil? SimpleXJ OEM Tech Discussion 6 December 18th, 2006 21:07
Moving Renix coil. Possible??? BIGSLVRXJ OEM Tech Discussion 11 November 2nd, 2006 19:37
renix coil, which wire for tach 87xjco Modified Tech Discussion 4 April 14th, 2006 12:19
New (to me) 1988 XJ Limited and a question Don Becker OEM Tech Discussion 13 July 16th, 2004 16:27
1988 Renix TPS readings gator_grabber OEM Tech Discussion 16 February 24th, 2004 13:57
