Old September 16th, 2010, 06:41
filterbiz filterbiz is offline
88 diagnosis equipment
Ok is there any diag equip or scanner for the 88 cherokee? what system do they run. thanks
Old September 16th, 2010, 06:56
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Re: 88 diagnosis equipment
No on-board diagnostics on an 88 (no OBD I or OBD II). Renix systems do not store codes. It can be put on a DRB machine at your mechanic for real time diagnostics. Unless you're willing to drop the $$ for that, all you really need is a Digital Multi Meter (DMM), and in some cases an analog meter. A test light is also a good thing to have around.
The only "emissions" light that will ever come on is the maintenance timer, which is more trouble than it's worth. If that light comes on, remove the bulb, and don't look back.
If you've never used a DMM:
http://a248.e.akamai.net/pix.crutchf.../000multi2.pdf
Old September 16th, 2010, 07:58
JJacobs JJacobs is offline
See if you can find a used Snap-On MT2500 with the Jeep-1 cable and card. My local dealer was selling them for $250. Bonus is you can also do OBD-2 with the same tool. It's very handy to be able to look at the live datastream for anything amiss.
Old September 16th, 2010, 09:39
joe_peters joe_peters is offline
The HEGO maintenance timer is located under the dash, driver's side, to the right of the steering column. It is a one-use only timer, about $60 to replace at the dealership parts counter. Just unplug the timer, the light will go out. It is a reminder to replace your o2 sensor, just track your mileage.
ParadiseXJ and JJacobs are right--real-time only system so no stored codes and no CELs.
Possible names for the engine management other than Renix: OBD-0; OBD-Less. Any other suggestions?
Old September 16th, 2010, 14:57
old_man's Avatar
old_man old_man is offline
I like my SnapOn 2500 brick. It really doesn't do anything you can't do with a good voltmeter, but it is a lot easier to use.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old September 27th, 2010, 07:08
MoFo MoFo is offline
Gone but not forgotten...
What is a reasonable price to expect to pay for the MT2500 with the Jeep 1 cable and card?
Old September 27th, 2010, 07:46
old_man's Avatar
$250 - $400 used for the 2500 model
Old September 27th, 2010, 09:41
BigSky89XJ's Avatar
BigSky89XJ BigSky89XJ is offline
You really can save yourself a lot of money if you have a Renix Fuel Injection manual and a decent digital multi-meter. Another good manual to have is the ignition manual for Jeep 4.0L Solid State Ignition (SSI). There really is not anything you cannot diagnose on a renix era Jeep with those things at your disposal.
Old September 27th, 2010, 11:16
Everybody says that- but the fact is you can diagnose ANY problem on any vehicle given a meter and enough time. However, the amount of time involved muddling around with a meter versus hooking up diagnostic equipment is very significant. I can tell you in 2 minutes which area to focus on with an MT2500 versus several hours of meter probing.
Old September 27th, 2010, 17:21
I have a couple of very good DMMs. I also have the Renix Fuel Injection Manual. I have never heard of the ignition manual for Jeep 4.0L Solid State Ignition (SSI). Any idea where I can pick one up?
I asked about the MT2500 because I have a chance to pick one up for $200. The seller is just confirming that it includes the Jeep-1 option.
Old September 27th, 2010, 21:09
MT Mike's Avatar
MT Mike MT Mike is offline
I'd buy the MT2500 with the Jeep service pack for that price. Damn handy tool to have, IMO.
Old September 27th, 2010, 21:40
magimerlin's Avatar
magimerlin magimerlin is offline
Very handy. I use mine all the time on both my 89's. I got mine with the case, a whole bunch of other cards and cables off of evil-bay for about 300 if I remember right. Well worth the money in my book.
Minimum Equipment Requirements, Safety Rules, Suggested Equipment GSequoia SoCal Fest 2010 7 February 3rd, 2010 19:59
Audio equipment, Lift equipment, and more... darwin For Sale: Private Party Only. XJ ITEMS ONLY 7 February 14th, 2007 21:32
diagnosis xjwisconsin OEM Tech Discussion 0 February 3rd, 2007 19:39
need help with diagnosis treedoc OEM Tech Discussion 11 August 14th, 2005 11:40
Help with diagnosis sprinkler1228 Modified Tech Discussion 9 September 7th, 2004 12:13
