Old September 14th, 2010, 19:25
aintright aintright is offline
wiring question...
hopefully this is a better place to get any kind of answer
i have a 93 2 door 4.0 aw4....
my headliner was shot so i got another one from a 99 2 door 2.5 ax5....
the 99 headliner has the integrated soundbar in the rear with the cargo light and a map light up front...
here's my question... how do i wire it so the lights only come on from the switches...
i found this link http://naxja.org/forum/showthread.ph...speaker+wiring
i found what wires do what... the only thing is on my wiring harness i have three wires...
pink - constant hot
yellow - switched hot from doors
purple - ???
the 99 headliner wiring harness is the same for the rear but only has yellow and pink up front...
sorry if this is rudementary but i'm pretty retarded when it comes to wiring...
if this isn't oem tech could the mods please move it where it should be... thanks...
Old September 14th, 2010, 19:38
Pelican Pelican is offline
NAXJA Member #1191
Re: wiring question...
I have precisely your year, 2dr and setup except for the '99 liner and speaker bar.
Someone will no doubt get on to help but I wanted to ask what exactly you mean by the lights only coming on from the switches? Do you mean not coming on with open doors?
Old September 14th, 2010, 19:43
Saudade's Avatar
Saudade Saudade is offline
Better than where?
Oh and x2 on Pelican's question. What do you mean by only the switches?
Old September 14th, 2010, 20:18
winterbeater's Avatar
winterbeater winterbeater is offline
The wire from the doors should be a switched ground. The way that the doors make the dome lights go on is by completing the ground at the door switch. The purple may be a ground going back to the light switch. Rotate knob all the way to make the dome light go on (check for completion of ground with a meter).
Old September 14th, 2010, 20:43
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Hope this helps- ehall covers the same details in a thread of his (not sure if it's in a build thread, or what, but he was installing additional lights in his hatch), but this covers the basics and some of the differences. I was scratching my head while putting my newer lights in, had to sort it out with a meter (I got it working, but I had the functions/polarity confused- ignore that bit).
http://www.naxja.org/forum/showthread.php?t=1010254
Found the other thread
http://www.naxja.org/forum/showthrea...=971921&page=2
Old September 15th, 2010, 15:36
thanks for the links... i'll check them out...
yeah i don't want the lights to come on when i open the doors... i just want them to be wired to their switches only... i kno i'm weird but i leave the doors open too much...
Wiring Question FlexdXJ Modified Tech Discussion 2 October 6th, 2009 10:38
CB Wiring Question 4x4ever Modified Tech Discussion 10 March 22nd, 2007 09:45
Tow wiring question jblaze5779 OEM Tech Discussion 1 April 17th, 2005 05:05
wiring question... red91 OEM Tech Discussion 3 July 23rd, 2004 19:47
XJ or MJ Wiring question fgcox1 OEM Tech Discussion 2 August 20th, 2003 14:29
