Old April 6th, 2010, 07:32
Joe's Avatar
Joe Joe is offline
NAXJA Member #887
Re: 241OR Rock-Trac/Teraflex 2-Low/Novak Cable Shifter Install
Originally Posted by pyrotyro View Post
question is, can i fix the speedo problem? because its now sounding like a rather large problem...
Not to big of a problem. Depending on the size of tire and gears your might be off by a couple of mile in speed. I am off 10 mile will traveling 65 not to bad. There are a couple off options to fix this problem but prices ranging from $70 - $250 I just don't worry about it too much right now since I only use the Jeep for off-roading.
Some option that I have found are:
The Yellow Box - http://yellr.com/index.htm
Heal Tech Electornics - http://www.healtech-electronics.com/
Dakota Digital - http://www.dakotadigital.com/
Superlift Truspeed - http://www.superlift.com/accessories/truspeed.asp
Old April 6th, 2010, 07:48
pyrotyro's Avatar
pyrotyro pyrotyro is offline
these all recalibrate the speedometer correct?
i am under the impression this jk case will not have a way to get the reading to my speedometer because jks are all digital right?
Old April 6th, 2010, 08:12
Joe's Avatar
Joe Joe is offline
NAXJA Member #887
Not sure about the JK but the TJ rubicon tcase is digital output. I installed a 241OR on my 94 XJ and any of these will correct the speed problem.
Old April 6th, 2010, 09:32
pyrotyro's Avatar
Just got off the phone with JB conversions. they have these cases and all sorts of flanges/adapters/sensors for them.
he said he would have to tear into the case some in order to get the case converted to vss... estimated at 250$ worth of work. he didnt give me too much detail on what all needed done specifically...
Old April 6th, 2010, 09:38
Joe's Avatar
Joe Joe is offline
NAXJA Member #887
Take a picture of the back of the tcase and post it. Not sure what it looks like. The 241or I have has a tone ring inside the rear tail output. When I bought my tcase I took it apart to inspect the internals so I know what it looks like.
Old April 6th, 2010, 09:51
pyrotyro's Avatar
You got it.
this has the stock output on it still. would have to be replaced with the 1310s (i think)
Old April 6th, 2010, 10:00
Joe's Avatar
Joe Joe is offline
NAXJA Member #887
You got it.
Look at the difference with the rear output:
Most likely JB Conversion will sell you a new tail cone, tone ring, sensor and possibly yoke.
Old April 6th, 2010, 10:03
Seiler's Avatar
Seiler Seiler is offline
Originally Posted by Doubleajaybrock View Post
Does the Standard Speedo gear not work to correct the speedometer?
Not in this application, no. These have a tone ring that spins as the main shaft spins. This creates a signal that is interpreted electronically, and then sent to the vehicles computer. The "standard/typical" Speedo gear is mechanical, and will not work with these cases. The tone ring is located in this image, in the middle under the nut:
Possibly a new shaft as well? I don't know, it's hard to tell. It looks like they could be comparable in length with all that extra material on his yoke.
Scott
Old April 6th, 2010, 10:05
pyrotyro's Avatar
holy hell. i see what he was referring too now...
dangit. i was really looking forward to having this case in my jeep. i cant afford to put that much more into it
Old April 6th, 2010, 10:37
Dundy's Avatar
Dundy Dundy is offline
I know you can go to jeep to get your pcm reflashed if you have a tj with a 241OR in order to fix the speedo. I wonder if you can do the same with the newer XJ's?
Old April 6th, 2010, 10:46
pyrotyro's Avatar
see the problem isnt the speedo being off. the problem is there is no connection for me to even get a speedo reading at all... without redoing the tailshaft
Old April 8th, 2010, 11:01
praetorian praetorian is offline
So do JK's use the wheel speed sensors to calculate speed like the WJ does?
Old April 8th, 2010, 11:40
stumpXJ stumpXJ is offline
You got it.
I have been down this exact road with the XJ. I had a normal 241 out of a JK, non rubicon/standard 2.72 reduction (still have it in the shop). Its exactly like your picture. There is no way to get a speedo signal from this case. I called PLENTY of folks that would know how (including JB), and they all told me I was wasting my time unless I wanted to do a lot of guess work.
It WILL bolt into the XJ once you swap to 1310's, and work just fine. In fact, its like a BEEFY NP231. The case is twice as thick as the 231, and everything inside of it is stronger... you just cant hook up a speedo to it. The JK's have speedo pickup in the front wheel/axle area, so there is no need for the VSS in the Tcase.
Since not having a speedo hooked up, it was throwing a VSS code, and that wouldn't allow me to pass inspection. I had to pull the JK Tcase out, and put in a 241OR (with the 4:1 reduction, out of a TJ rubicon), and my stock speedo hooked right up, code went away, and the inspection people were happy.
~ James
Old April 8th, 2010, 15:49
pyrotyro's Avatar
~ James
Yeah im bummed because the thing is so much burlier then the 231 (and i hate to lose the 4:1 i have now)... but without extensive work ($$$) i cant make it work
Old April 8th, 2010, 16:08
Seiler's Avatar
Hey Pyro, can you do me a favor and take a picture of the tag on your case? It should look something like this:
Try to get close enough so the lettering is legible.
Thanks,
Scott
Novak shifter and the 2-low kit xjtrailrider Modified Tech Discussion 4 March 31st, 2009 19:12
Novak T.C. shifter SUA SPONTE Modified Tech Discussion 14 January 23rd, 2008 19:15
Novak SHifter Q's Kejtar Modified Tech Discussion 20 May 8th, 2006 21:40
Novak shifter for the 231? Kejtar Modified Tech Discussion 9 March 5th, 2005 04:44
