Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  #646
Old August 30th, 2019, 15:42
techno1154's Avatar
techno1154 techno1154 is offline
Re: Vanilla Gorrilla blog
[QUOTE=GordoSmasho;246660544]
Originally Posted by techno1154 View Post
Hey bud
So yes that is a jk44 rubicon front. No i dont have a truss and it is not needed. I sleeved the tubes with a very simple kit. And gusseted the inner Cs. Our xjs are not heavy like the jks are and i dont plan on jumping my rig so im good. As far as mounts. The only things i moved to make things simpler was the coil/shock mounts and the trac bar mount. The jk coil mounts are centered. They need to be forward of the tube for the xj. And I lowered my shock mounts so I could swing a 12 shock on 3 of lift. Then i got a rustys factory xj axle trackbar bracket and placed it in the factory xj location on the jk axle. So the only thing that needed modding was my draglink length to get it to work. Xj under axle track bar works for me. Btw. All of my link mounts are stock jk mounts. They are in the same locations about as the xj. Hope that helps. Any other questions let me know.
That is of great help to me. No more agonizing over welding a truss. I will just spring for an axle bracket kit and the tubes then I will be good to go.
I saw online a wire harness kit for the locker that I need to get unless I can get connectors then make my own harness.
Great info my friend.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old August 31st, 2019, 06:34
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
[QUOTE=techno1154;246660586]
Definitely still do a sleeve and gusset kit.
This is a good kit
https://www.4wheelparts.com/p/2017-J...SABEgLo4fD_BwE
And these coil mounts from rustys have the track bar bracket as a part of the mount. Wish i would have gotten these. Would have made it easier
https://www.rustysoffroad.com/builde...ock-mount.html
And i used these to mount my shock lower on the axle tube.
https://www.ruffstuffspecialties.com...SABEgJ-zPD_BwE
Again the control arm mounts dont need to be changed.
Old October 14th, 2019, 18:04
Went out with some battle born xj guys sat night and ran a local trail. Bud Canyon. Here are a few pics. The 37s are tucking quite nicely.
Old October 14th, 2019, 18:05
Old October 15th, 2019, 09:01
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
I dig it man!
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old October 16th, 2019, 04:55
SlowXj SlowXj is offline
Your approach angle is insane. That would almost crawl a vehicle wall..
Old October 16th, 2019, 22:12
Thx man. Not sure a vertical wall. Its still about 80degrees or so. I have seen many well built rigs get denied the proper line because of a big bumper. Or broken tire carriers dropping off an obstacle. Good angles are key.
Old October 20th, 2019, 20:46
Alboy97XJ Alboy97XJ is offline
Omg is that a 4runner?! 😍
Sent from my VS996 using Tapatalk
Old October 20th, 2019, 21:44
Yeah two of them followed us up this trail randomly.
Rate This Thread:
The alien blog frontman Sierra Chapter 16 April 29th, 2012 16:09
Blog RescueGreenXJ Non-Tech / Off Topic 2 December 16th, 2011 11:24
Blog fun... 5-90 Non-Tech / Off Topic 0 November 14th, 2010 20:58
Vanilla Ice and MC Hammer .. together at last. urban yan Non-Tech / Off Topic 4 February 13th, 2009 12:43
Vanilla Pudding Robbery bjoehandley Non-Tech / Off Topic 3 June 5th, 2007 20:49
