Old June 10th, 2021, 13:29
rstickley rstickley is offline
Control arm drop brackets ?
I have a 98 with a 3" lift. I was looking for a control arm drop kit but the ones I find are all for 4" + lift. Has anyone installed one of these kit with a 3" lift and had good results? Thanks.
Old June 10th, 2021, 13:50
RCP Phx RCP Phx is offline
Re: Control arm drop brackets ?
The only issue I could see is finding a set of upper/lower control arms that can be adjusted that short.
Old June 10th, 2021, 14:13
Evan03 Evan03 is offline
I'd run stock arms and go from be about the same as a bone stock xj with sagging springs
Old June 10th, 2021, 15:27
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I drove 40,000+ miles and 4 wheeled in both Ouray Co and Moab Ut with a 3 inch lift that included longer lower control arms, but without control arm drop brackets. The vehicle ride comfort and driveability was not compromised. I don't think the benefits will outweigh the costs at only 3 inches of lift.
At 4.5 inches of lift, the ride comfort went to heck and potholes and railroad tracks were sharp impacts to the unibody that reverberated in my kidneys. Control arm drop brackets improved the control arm angles, and the ride comfort as well.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old June 10th, 2021, 20:17
The problem is in the ride quality. It sucks. It is a Trail Master lift kit that came with coil springs, lower control arms, sway bar drop brackets, and rear add a leaf, and shocks. It hits hard and jolts the body when going over even cracks in the road. I installed Bilstien shocks and it helped some. The lower control arms are pointed up at a 12 degree angle from the axle. From what I have read, it seams that to get the ride better, this angle needs to be closer to 0.
Old June 10th, 2021, 20:22
I have to disagree. With 2-3" lift stock arms stock brackets ride pretty much sucked. I can't compare drop brackets because I never ran then.
But going to longer arms upper and lower axle points raised to nearly flat lower arm. Ride improved to better than stock.
I currently could take speed bumps at 45 even square edged side walks. Actually I bump off stuff all tge time just for fun.
Ounce the xj is lifted ride quality is compromised the drop brackets help get the geometry back to livable levels. If lifted 3" geometry is nearly where the engineers wanted it to be.
Old June 10th, 2021, 20:29
They say no more than 6deg anything with a link suspension not just the xj. Who they is i dunno but I read it somewhere and it's working fir me after building cutting apart and redoing my front 3 link a few times.
You may or may not see benefits from investing in different shocks and springs but you will certainly see instant improvement when the geometry is in a happy zone where arms are flat ass possible here suspension works from the center of the arc not near the bottom of it
Old June 11th, 2021, 03:50
Tim_MN's Avatar
I suppose ride quality is subjective. I don't know what shocks or what spring rates Trial Master kits use, but my 00 has 3.5" RE springs and DoetschTech shocks, and my 98 has 3" Rusty HD coils and Bilstein 4600. The ride quality is similar and I don't find it objectionable.
Old June 11th, 2021, 04:54
SlowXj SlowXj is offline
With drop brackets and a 3 inch lift you may have excessive brake dive due to geometry.... I would try it though. Worse case get a 1 inch spacer...
Old June 11th, 2021, 06:30
I dont think brake dive will change noticably because link seperation at both ends is retained.
Geometry is not subjective like shocks and springs
Old June 11th, 2021, 06:35
Does a bone stock xj with worn springs from living life have brake dive, maybe it has no lift and a baddass winch. Ive drove a few stock jeeps and not noticed brake dive.
Only time I noticed brake dive was when I didnt have enough axle side link seperation on my 3 link
Maybe its springs have not settled since leaving the plant
Old June 11th, 2021, 07:01
My stock 99 has excessive brake dive imo... Way more than the iro 3 link
Old June 11th, 2021, 09:31
TRCM's Avatar
TRCM TRCM is offline
I have drop brackets and 3 3/4" lift....stock uppers and WJ lowers.
Rides awesome and no issues.
Old June 12th, 2021, 07:36
Slow thats weird.
Id like to drive it and get a real world comparison to what I have experience with
Old June 13th, 2021, 06:55
It is strange. It's sagged about an inch and the shocks are just run of the mill Gabriels, but the five is very noticeable compared to the iro 3 link with 3.5 inch lift
looking for control arm drop brackets kpeeks Red River Chapter For Sale/Wanted 1 April 17th, 2015 06:39
control arm drop brackets NorCalChris Modified Tech Discussion 6 April 27th, 2009 20:15
WTB: RE control arm drop brackets Mr. Pickle SoCal For Sale 2 January 15th, 2008 09:00
RE control arm drop brackets xjj33p3r Wanted: Private Party Only 4 September 10th, 2004 17:00
