Old May 15th, 2012, 20:14
bigjeepman's Avatar
bigjeepman bigjeepman is offline
4.0 and aw4
In process of doing engine and tranny swap. Problem is tranny i got is from 98-99 and motor is out of 94-95. I dont drive on road at all! This is strictly trail only rarely ever over 5 to 10mph. My question is will tranny still operate without input from ecm. I have tcm and harness for tranny but the engine harness and tranny harness wont plug up.
Old May 15th, 2012, 20:16
bigjeepman's Avatar
Re: 4.0 and aw4
Again strictly trail only. I really only want first gear and maybe 2nd. Dont neex 3rd or od at all
Old May 15th, 2012, 20:52
88_cherokee's Avatar
88_cherokee 88_cherokee is offline
Re: 4.0 and aw4
i would think if you use it manually, it would/should work fine
Old May 16th, 2012, 06:38
O-Gauge Steamer O-Gauge Steamer is offline
Re: 4.0 and aw4
You can run the transmission without a PCM with switches and relays.
Do a quick search here as the solenoid combination for the gear selection is well documented.
Old May 16th, 2012, 20:20
bigjeepman's Avatar
Re: 4.0 and aw4
i know about controlling it with solenoids and switches but i was under the impression that you could not manually shift the 1998 and newer model aw4's because they changed the solenoids.
any clarification on that. i think i read that here in someone's aw4 bible of all models from different years
Old May 17th, 2012, 13:31
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: 4.0 and aw4
You can do it on the new models, but you will get a CEL from the ecu not seeing the transmission controller.
