Old February 9th, 2019, 14:42
jeeping4fun's Avatar
jeeping4fun jeeping4fun is offline
Brake booster and MC swap issue
Hey guys
I have a 87 MJ that I swapped a 96 booster and MC into. I just took it for a drive and when pushing the brake I get nothing until the last inch or so then it goes full brake. Like lock the tires up lol.
The booster and MC were new. I left the original praportioning valve. Bench bled the mc and bleed almost 64 oz of fluid through.
I also put new calipers and brakes pads/rotors on.
Any suggestions?
Also when I hit the brakes with it off I can hear a suction sound coming from booster/mc area.
Thanks
Old February 9th, 2019, 16:03
paulhead's Avatar
paulhead paulhead is offline
I overtighten $#!t
Re: Brake booster and MC swap issue
That suction sound may be a bad booster, I went thru 2 before finding a good one. Also thoroughly bleeding the brakes is essential. I had a to more than once.
“Lead me, follow me, or get out of my way. ”
-Gen. George S. Patton Jr.
Back at step 1, bought a YJ, an XJ going under the knife....
Old February 9th, 2019, 18:09
Damn ok. Its brand new but who knows. I'll take it back and get another new one.
I just bled them again and still the same. I'll try it again in a couple days and see if it just has that much air. Crazy I've put like 80oz through it now.
Thanks
Old February 10th, 2019, 06:58
Jim Malcolm Jim Malcolm is offline
You may have an air bubble trapped in the proportioning valve. Just loosen the end, fluid will come out. Be careful, there's a spring behind it, so it can be a bear sometimes when your hand is covered in fluid. At this point you're half way to putting the proper proportioning valve in their. You don't need to replace the body, just the screw in piece and the spring out of a ZJ. I prefer not to wear out my brakes prematurely when the fix is so easy and inexpensive.
Old February 10th, 2019, 07:23
RCP Phx RCP Phx is offline
Did you get the pushrods(there are 2) adjusted properly?
Old February 10th, 2019, 09:48
I'll try to crack the valve. I did the rear disc brakes on my xj and upgraded the spring. Does the ZJ spring fit in the old style propotioning valve?
I did not adjust any pushrod. Where are these located?
Old February 10th, 2019, 09:53
You've got one between the pedal and the booster, and one between the booster and the master cylinder.
Old February 10th, 2019, 09:58
I didnt adjust either. I did add a 1/4" spacer between the booster and fire wall so I didnt need to trim the fire wall. Also by doing that the length of the rod inside the cab would be the same. If I didnt the pedal all the way up would have a 1/4" of pressure into the booster.
I also didnt mess with the one from the booster to mc.
I am looking at it again now and the MC is the one making a noise when I let off the pedal. Sounds like its ducking air. I cant find a leak anywhere. Damn thing.
Old February 10th, 2019, 10:24
Well I think the sound is inside the MC. Waiting on my wife because I can push the pedal and run to the front in time.
Also I got those quick bleeders so i could bleed them myself. Tried to save myself from the peanut gallery. "How long will this take" "my leg is tired". Anyways gonna replace those and bleed it with two people. If I cant get the air out then I'll assume the MC is bad and replace it...again. it will be a couple weeks before I have time but I'll update once I find the problem.
Old February 10th, 2019, 11:36
I am looking at it again now and the MC is the one making a noise when I let off the pedal. Sounds like its sucking air. I cant find a leak anywhere. Damn thing.
It's not to likely on the sound being the MC would/could be air. There is a gasket that can leak air between the MC and the booster.
Old February 10th, 2019, 11:55
Ok I got an extra gasket. The MC came with one and the booster came with one. I'll swap it out and see before completely changing out the MC.
Old February 12th, 2019, 07:30
So these are ZJ rear disc's installed on a D35?
Old February 12th, 2019, 10:00
No I have a dana 44 with drums. I just upgraded the MC and booster to a 96 XJ.
My other jeep XJ I did a rear disc conversion and upgraded the spring.
Since my MJ is drum in the rear that's why I was asking if I should do the spring? I never heard of doing it in any of the mc booster upgrade threads.
Old February 12th, 2019, 10:15
Borgli Borgli is offline
For me the pushrod was a bit short so(if I recall right) I unscrewed the one in there and replaced it with a longer bolt that I cut the head of. I went from braking 300ft early to almost slamming my face into the steering wheel. Can't believe I waited 2 years to check something so simple. Anyways, check your pushrod.
Old February 12th, 2019, 10:18
Ok got it. I'll check when I take it apart again... thanks for the input
brake booster swap without MC jeeptorino68 Modified Tech Discussion 1 May 2nd, 2015 16:06
Brake booster/MC swap MoabXJeeper Modified Tech Discussion 15 May 8th, 2014 13:42
Brake booster swap and brake switch 89 and ? Ecomike Modified Tech Discussion 4 February 19th, 2011 08:12
XJ Brake Booster swap jcnoble Modified Tech Discussion 24 January 21st, 2009 03:50
need help with brake booster swap thisfirstlove Modified Tech Discussion 1 May 10th, 2005 10:30
