Old January 28th, 2019, 18:52
craiso craiso is offline
'91 Laredo 4WD Components going into '98 Sport 2WD
My beloved 1991 XJ with 380,000+ original miles has become a donor due to a recent roll-over. I understand that most of the work will be a direct swap into my 1998 XJ Sport 2 Door, 2WD. I plan on using the front and rear differentials, transfer case, and both drive shafts from the '91. I am not clear on how the speed sensor on the transfer case will be integrated in to the '98, or if it is even needed. And then there is the 4WD indicator switch on the transfer case. I can see there is a light on the instrument panel, so is there a known method to make it work as well? I have read a few similar build threads. They concentrate on adding the 4WD and usually a lift, but not much information on how to get the required electrical components working. Looking forward to comments... Thanks
Old February 8th, 2019, 15:27
Re: '91 Laredo 4WD Components going into '98 Sport 2WD
I just did a equipment list search by VIN. Listed for the transmission is AW4, and for the rear differential is corporate 8.25. Does this mean that I can simply add my transfer case and front differential from my donor and be done with it? Please see the information below...
Equipment Listing
Vehicle Description 1998 JEEP CHEROKEE SPORT UTILITY 2-DR
Monotone Paint
117 Amp Alternator
500 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
Reclining Front Seats
Rear Fold w/Removable Cushion Seat
Traveling Inboard Seat Belt Buckle
Next Generation Front Air Bags**
Carpets - Floor and Cargo Area
Cargo Compartment Carpet
Cargo Tie Down Loops
Plastic Liftgate Trim Panel
Passenger Assist Handles
Lift Gate Assist Handle
Full Length Floor Console
4-Speed Automatic AW4 Transmission
Corporate 8.25 Rear Axle
Tinted Windshield Glass
Front Door Tinted Glass
Tinted Rr Drs/Qtr/Liftgate Glass
Rear View Day/Night Mirror
Deluxe Insulation Group
100 MPH Primary Speedometer
STANDARD EQUIPMENT
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
DK QUARTZ - "CHEROKEE" Badge
DK QUARTZ - "JEEP" Badge
RADIANT SILVER MET. C/C - JEEP
BLACK - FENDER FLARES
Headlamps On Warning Chimes
Glove Box Lamp
Front Dome Lamp
Halogen Headlamps
CHMSL Lamp
Front Bumper Guards
Black Windshield Moldings
Rear Qtr Solid Window Insert
Belt Moldings
Body Color Drip Trough Molding
Black Door Handles
Silver/Chrome Badging
EVAP Control System
20 Gallon Fuel Tank
Stone White C/C
Power Steering
Normal Duty Suspension
Front Stabilizer Bar
Rear Stabilizer Bar
Compact Spare Tire
Inside Mounted Spare Tire
Upgraded OBD-II Connectors
Tethered Fuel Filler Cap
Build To U.S. Mkt. Specifications
GVW Rating - 4550#
U.S. Dealer Retail
Zone 63-Dallas
Texas Ship to State Code
Texas Sold to State Code
Prem Cloth Hi-Back Bucket Seats
Indigo/Linen
SE Decor Group (97-02-26)
4.0L Engine(ERH)/4Sp Auto Trans(DGS
High Back Bucket Seats
Highline Door Trim Panel
Front & Rear Floor Mats
Spare Tire Cover
All 4-Speed Automatic Transmissions
Lock-Up Torque Converter
Floor Mount Automatic Shift Lever
3.55 Rear Axle Ratio
All Engines
4.0L I6 Power Tech Engine
Power Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Air Conditioning
Analog Instrument Cluster
Instrument Panel Black Bezel
OPTIONAL EQUIPMENT
Rear Window Wiper/Washer
DK QUARTZ - "4.0L" DECAL
Cargo Compartment Lamp
Black Front Bumper
Black Rear Bumper
Front License Plate Bracket
Black Grille
Roof Rack
Federal Emissions
Stone White Clear Coat
All Radio Equipped Vehicles
AM/FM Cassette Radio
4 Speakers
Fixed Long Mast Antenna
Luxury Steering Wheel
Tilt Steering Column
P215/75R15 BSW Wrangler AP Tires
Goodyear Brand Tires
15X7.0 Styled Steel Wheels
All Steel Wheels
8 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TB
Customer Preferred Package 26B
Spring Special Discount
Old February 8th, 2019, 18:25
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The 91 transmission and transfer case are not a bolt on swap to a 98 and are not recommended. The axles and front drive shaft are bolt on.
I would suggest you need to do some more research about your swap to 4x4. Start by reading this AW-4 swap info thread >> https://www.naxja.org/forum/showthread.php?t=1053970 << Note that you will need a 4x4 transmission, and a transfer case that has the correct input shaft length and spline count, as well as the correct speedometer output.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old February 9th, 2019, 13:58
This is obviously a much larger project that I have ever tried to accomplish. I have no problem troubleshooting and changing parts; I worked on planes for 25 years. I have read a few threads now about the 2WD to 4WD conversion and its complexities, and thank you for pointing me to another I do appreciate it. After looking over Kastein's post, I understand that the '91 transmission will not work for me. It also seems that the '98 2WD AW4 cannot be converted to 4WD without more work than I am capable of doing. I did some digging and found an interchange part number 400-03265; is this what I am looking for? I imagine that I will need the '98 transfer case as well...
Old February 9th, 2019, 16:48
Tim_MN's Avatar
Using the correct era parts will make your project a bolt on job. Find an appropriate 98-01 donor and grab the 4x4 transmission, attached transfer case, the 4x4 shifter assembly, and the possibly the rear driveshaft if the donor has a Chrysler 8.25 rear axle. You will likely need or find very useful the transmission/transfer case wire harness as well. I find www.car-part.com useful both for locating parts and for helping determine part compatibility/interchangeability. When you give them your vehicle details the list of available parts shows only exact interchange donors.
Old February 9th, 2019, 18:51
Tim_MN you are the MAN! I can't thank you enough for the link. I'll let you know how it turns out.
Old February 22nd, 2019, 20:02
Change of plan. I think I will be going the easy route and add an auto locker to the axle and slap on some AT tires to make the best of it. I know the differential is a corporate 8.25, and assume that there are 29 spline shafts. Taxes are done, so I've been looking at a Spartan Lunchbox and a Lube Locker gasket to finish up. Thoughts?
Old February 22nd, 2019, 21:36
Heavyopp Heavyopp is offline
Only you know if you need 4 wheel drive -- Did you use it much on the rolled cherokee?
I have both a 2000 4wd and a 96 2wd cherokee -- The 2wd is new to me -- at the moment I'm keeping it 2wd but if the right donor shows up then It'll be hard for me not to swap it -- the 96 2wd has 100,000 less miles than the 2000 4wd -- I got the 96 for $400 and was being used as a daily driver by previous owner
Old February 23rd, 2019, 06:21
Tim_MN's Avatar
A locker and good tires are the foundation of good traction. All of the LockRight/Spartan type lunchbox lockers perform well and are simple to install.
Keep your eyes open for a suitable donor for the 4x4 parts, you can always install them at a later time. Often you can buy a complete wrecked or project Cherokee for very little and then recover much of the purchase cost selling the 2wd transmission and other parts and in the scrap value of the metal.
Old February 23rd, 2019, 15:27
I miss the '91 already with all the weather we are getting. I did use the 4WD often this time of year out here on the Missouri River bottom. Someday I'll eventually convert this one to 4X4; it's growing on me. ��
Old February 24th, 2019, 10:12
Would I be inducing issues to my suspension if I went ahead and swapped out the front axle?
Old February 24th, 2019, 12:54
Tim_MN's Avatar
As long as the steering and suspension parts are in good or new condition there will be no issues.
Old February 24th, 2019, 13:49
One less thing to do later... Thanks.
Old February 24th, 2019, 19:27
Shouldn't be much of an issue -- maybe just a little loss in gas milage compared to the 2wd front axle
Old March 2nd, 2019, 18:35
I bought a Spartan lunchbox and installed it today. Had a small SNAFU with not getting one of the C clips in all the way, but it finally worked itself right. Did it the old fashion way outside in the wind and the cold. We had a high of 20* today. Took breaks often, so I survived. It seemed to perform well. Now I need some better tires. General purpose tires in this year's winter just isn't getting me anywhere. What should I be expecting to get out of this RWD Jeep with the lunchbox?
WTS 96 laredo sport seats. Whitetaild33r NAC Classifieds 0 March 17th, 2011 19:11
Will a 1990 XJ Laredo T-Case swap into a 1994 XJ Sport? ItZaJeePThiNG Modified Tech Discussion 6 February 1st, 2009 10:02
93 Laredo vs. 97 sport SLAYER Non-Tech / Off Topic 16 January 17th, 2007 23:10
98' ZJ Laredo, 98' XJ Sport, 87' XJ Laredo for sale in Sacramento, CA Big Red For Sale: Private Party Only. XJ ITEMS ONLY 4 June 8th, 2006 17:18
