Old February 1st, 2008, 09:56
67TEMP 67TEMP is offline
231 true nuetral swap
I have an 87 that locks the two drive shafts together when in nuetral. I plan to do an sye on it soon but would like to change it to a true nuetral like the later years while I have it apart. I also have a broken 231 from my 98 to use as donor. What parts would need need to be swaped?
Old February 1st, 2008, 10:05
ddeadserious's Avatar
ddeadserious ddeadserious is offline
Re: 231 true nuetral swap
I don't think there ever was a "true neutral" in the NP231. My dad has an 04 Wrangler, and the neutral is the same way. The main point in the T-case neutral is for flat towing, you put the t-case in neutral, and the trans in park.
Someone please correct me if I'm wrong.
Old February 4th, 2008, 16:39
My 98's orginal t-case, the current one in it from a 96, and my 99 xj all allow the rear tires to spin when in nuetral and both rear tires off the ground. My 87 does not do that. Both front and rear shafts are locked when in nuetral. I plan to eventually flat tow it and dont want to keep pulling the shafts.
Old February 4th, 2008, 16:51
Ray H's Avatar
Ray H Ray H is offline
Im not sure what year the switch to a true "N" was but it was sometime before 96, as my 96 also has it. I dont know what parts would need to be changed. DDeadserious, I think if you double check that 04 Wrangler you will find out that it does in fact have a true "N".
Old February 4th, 2008, 16:52
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
just the shift mode needs to be changed...
another option would be to buy the teralow 2-low kit... this has true-neutral...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old February 4th, 2008, 17:23
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
My 87 has true neutral? :shrug:
It's sad, but true... RTicUL8 Non-Tech / Off Topic 15 January 19th, 2008 17:04
Is this true? IntrepidXJ Non-Tech / Off Topic 32 October 21st, 2007 02:00
WTB: NUETRAL SAFETY SWITCH FOR 96 AUTO jack96xj SoCal For Sale 5 June 3rd, 2007 16:36
could it be true anewlife84 Modified Tech Discussion 11 October 18th, 2006 20:56
nuetral saftey switch won't go back on jpxj94 OEM Tech Discussion 1 July 31st, 2004 15:23
