Old July 22nd, 2021, 04:45
giacomo.m giacomo.m is offline
Re: Booster Upgrade
Hey,
thank you so much for your answer
so do you think the BLA-G360 / BLA-R340 / BLF-31B / BLF-33B that I bought are not okay ?
thank you
Giacomo
Old July 22nd, 2021, 08:42
jeepboy12001 jeepboy12001 is offline
Re: Booster Upgrade
Originally Posted by giacomo.m View Post
Hey,
thank you
Giacomo
You'll need to extend the BLA-G360 and BLA-R340. 8 inches is not enough to make it over to the propotioning valve.
If its not your daily I would also check and make sure your fittings arn't frozen in the proportioning valve. If they are you will have to take another path with the connections.
Old July 22nd, 2021, 08:44
Re: Booster Upgrade
Might also pick up a brake line bending tool and some flare nut wrenches. They will make your life easier.
Old July 22nd, 2021, 13:56
Re: Booster Upgrade
" If they are you will have to take another path with the connections."
that is, what should I have in stock ?
thank you
Giacomo
Old August 3rd, 2021, 04:55
Re: Booster Upgrade
Thank you jeepboy12001
so if i buy 2 flexi lines (52128086/52128087) which fittings should i use to connect the hoses to the proportioning valve ?
Giacomo
Old August 5th, 2021, 10:52
Re: Booster Upgrade
Hi all,
nobody knows which fittings I have to buy for connect the 2 flexi lines to the proportioning valve ?
thank you
Giacomo
Old September 23rd, 2021, 13:07
Re: Booster Upgrade
Hi all,
update of problem,
in the end I to fit the 2000 WJ master cylinder and brake booster with the fittings and tubes that I described a few posts ago, with new rear brake drums and new brake cylinders
the braking has improved considerably, but the brake pedal has a too long stroke, it acts only in the last part of its stroke. is this normal or can I do something ?
how can i attach pics ?
thank you
Giacomo
Old September 23rd, 2021, 18:21
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Booster Upgrade
adjust up the rear brake shoes first. Perhaps re-bleed the system.
Old September 24th, 2021, 04:58
Re: Booster Upgrade
Already adjusted the rear brake shoes, in fact now the wheel is slightly braked....
do you know how to attach pics ?
thank you
Giacomo
Old September 24th, 2021, 18:06
cruiser54's Avatar
Re: Booster Upgrade
Have you bled the brakes again?
RR,LR,RF,LF
Old September 25th, 2021, 00:27
Re: Booster Upgrade
bleeding done 3/4 times...
Giacomo
Old September 25th, 2021, 07:56
cruiser54's Avatar
Re: Booster Upgrade
Did you bleed the master cylinder first?
Old September 25th, 2021, 11:07
Re: Booster Upgrade
Yes on bench....
Giacomo
Old October 10th, 2021, 06:28
Re: Booster Upgrade
Hi all,
as already mentioned, the swap has brought about a 100% improvement in braking (even if in the first part of the brake pedal stroke there is no effect) but now I no longer have the rear brake lights ...
brake light switch or an adjustment problem of the same on the brake booster rod ?
thank you
Giacomo
Old October 10th, 2021, 06:32
Re: Booster Upgrade
I also saw that there is another white switch on the brake pedal, on the top what is its function ?
could it possibly be used for the rear stop lights ?
Giacomo
Booster upgrade ! PMGaming101 Modified Tech Discussion 10 October 13th, 2014 06:16
Brake upgrade question non-abs booster to abs booster 94xjstud Modified Tech Discussion 3 February 3rd, 2010 10:12
99 Brake Booster Upgrade!!!! AZRockRunner Arizona Chapter 0 May 8th, 2007 21:47
WJ brake/booster upgrade,.. bxj Modified Tech Discussion 0 August 25th, 2006 22:11
Upgrade to 95 booster,M/C redwagon Modified Tech Discussion 8 September 17th, 2003 17:50
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
