Old December 31st, 2018, 13:36
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Booster Upgrade
Please report back.
Old January 3rd, 2019, 10:40
offroadman83's Avatar
offroadman83 offroadman83 is offline
Booster Upgrade
Glad this came up...i really gotta get better brakes for my 91 and wanna swap in something better. Especially since im about to upgrade to 33s.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old January 8th, 2019, 10:40
Pclem11 Pclem11 is offline
Re: Booster Upgrade
Man I'm glad I saw this right after joining. I've currently got an 87 that the booster is about shot. Has a fat vacuum leak ( brakes still work though) so I think instead of replacing with factory parts, it'd be a good time to upgrade.
Old February 17th, 2021, 08:29
Black1990jeep Black1990jeep is offline
Re: Booster Upgrade
Originally Posted by cruiser54 View Post
WJ versus 95 to 96 XJ booster
Actually, the WJ booster is in some ways easier than the 95 to 96 XJ.
I've done both.
XJ, you don't have to mess with the firewall. No big deal anyway.
But, you have to move the washer reservoir. And, once the original booster comes out, the bracket inside the cab moves and makes it a bear to install the new booster.
WJ you have to bend or cut the firewall lip, but don't move the washer bottle.
As an added bonus, the mounting studs of the WJ booster are a bit smaller and it's easier to get in.
Another bonus with the WJ is that it has FLEXIBLE lines from the master cylinder that make putting things together MUCH easier.
And, WJ boosters are newer and easier to findů..
Got some questions
1... For my 1990 XJ, which year WJ booster is used for this upgrade?
2... given I have rear discs on my XJ ( Ford Explorer disc) do I keep my proportioning valve, eliminate the valve, or use a WJ valve, or...?
3... Is the WJ master used with this conversion?
thanks
Old February 17th, 2021, 17:03
cruiser54's Avatar
Re: Booster Upgrade
99 t0 2004 WJ booster/master assembly with the flexible lines. Grab the guts of the prop valve from the donor WJ and swap them into your prop valve.
Old July 15th, 2021, 14:01
giacomo.m giacomo.m is offline
Re: Booster Upgrade
Hi all,
I too would like to make the modification to the brakes of
1990 XJ Renix with 2000 WJ brake booster & mc,
but I would kindly like to know the part number of wj flexible lines to prop valve, and
if perhaps it is better to fit the following spare parts:
BLA-G360 AGS
BLA-R340 AGS -
BLF-31B AGS -
BLF-33B AGS
Thank you
Giacomo
Old July 15th, 2021, 14:23
cruiser54's Avatar
Re: Booster Upgrade
Are you buying the parts new, or getting them from a junkyard?
Old July 16th, 2021, 00:11
Re: Booster Upgrade
Thank you cruiser54
new parts
Giacomo
Old July 16th, 2021, 00:30
Re: Booster Upgrade
Also do you think i will have to move the bootle washer ?
thank you
Giacomo
Old July 16th, 2021, 05:08
cruiser54's Avatar
Re: Booster Upgrade
No. But you may have to cut the lip on the firewall a bit.
Simple to do. I have photos but I can't post them here. Give me an email address and I'll send them to you.
As for those lines, they should be available from the dealer.
Old July 16th, 2021, 08:02
Re: Booster Upgrade
For the brake lines is it better to buy the 2 original spare parts (whose codes I cannot find in the spare parts catalog) or take the AGS pipes and fittings ?
email :meraviglia.g@gmail.com
thank you
Giacomo
Old July 16th, 2021, 09:08
cruiser54's Avatar
Re: Booster Upgrade
2 original is best.
You will need a flaring tool to change the end at the proportioning valve.
Old July 16th, 2021, 13:05
Re: Booster Upgrade
but do you know the part numbers of the 2 brake lines ?
Giacomo
Old July 16th, 2021, 23:52
Re: Booster Upgrade
Hi all,
nobody knows the part number of the 2 flexi lines ( of WJ mc ) to proportioning valve ?
thank you
Giacomo
Old July 21st, 2021, 15:41
jeepboy12001 jeepboy12001 is offline
Re: Booster Upgrade
Originally Posted by giacomo.m View Post
Hi all,
thank you
Giacomo
Hey, I just went through this.
I used these to convert the bubble flared metric fittings on the WJ MC to standard 3/16 24 inverted.
BLA-O380
BLA-B312
BLU-3 ( two of these )
Then I made lines from the BLU-3's to the prop valve. You can purchase the two prop valve fittings on the AGS site as well.
You will need an inverted double flare tool. Do not use the rented ones as they are trash. Purchase the Napa SER 161A.
You could also purchase just the fittings and run a new lines, but since one of mine was frozen in the prop valve I had no choice.
I also added the 1/4 inch spacer in between the booster and the firewall. My pedal is 4.5 inches from the floor. It was 5 inches from the floor with the old booster. So the space is not required.
It will lock up the front tires now and feels safer so it's def worth the headache.
Hope this helps.
Booster upgrade ! PMGaming101 Modified Tech Discussion 10 October 13th, 2014 06:16
Brake upgrade question non-abs booster to abs booster 94xjstud Modified Tech Discussion 3 February 3rd, 2010 10:12
99 Brake Booster Upgrade!!!! AZRockRunner Arizona Chapter 0 May 8th, 2007 21:47
WJ brake/booster upgrade,.. bxj Modified Tech Discussion 0 August 25th, 2006 22:11
Upgrade to 95 booster,M/C redwagon Modified Tech Discussion 8 September 17th, 2003 17:50
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
