Reclipse
- Aurora, CO
Hey guys, I need some input. 93 cherokee sport, 4.0, auto, 231, 4" lift. It all seem to have started when I put some winter tires on this thing. I went from 31/10.50/15 MTR Kevlar to Cooper M/S 265/70/15. There are definitely lighter, and this is only temporary until the winter season is gone, yes I do know they are smaller than the 31's.
They seem to follow the grooves fairly persistently, its like I have no control of the vehicle. I replaced the tie rods because of some movement, I actually upgraded to the ZJ tie rod. It seemed to have made the wandering worse. I adjusted the toe, and everything is tight. So I figured the caster was off, I set it to 5°, rechecked the toe. That seemed to have made it better, until I decided to drive it more. On my way home I was white knuckling it on the highway, no fun to drive it anymore. Ball joints have no movement, trackbar ha no movement, and frame doesn't seemed cracked nor is there movement on the gear box.
Here is what I noticed after everything, I seem to have a lot of wiggle in the steering, I am going around a corner and then it seems to almost want to straighten out or go straight even though the wheel is still turned. Like a dead spot when turning. I was at home this morning, I probably have about 6" or more of wiggle before it seems to move the tires. I adjusted the steering box to reduce the wiggle, but doing so now it just feels dangerous to drive it, will not stay straight no matter what I do.
Before I get a new steering box, since I feel this is my last resort, wanted some opinions before dropping that much coin to only have the same issue. I have searched all over the place, which makes me to believe its the box.
