Old June 25th, 2012, 14:17
Rags Rags is offline
Re: Renix Fuel Line o-ring question
Thanks guys for the part numbers......
Napa is the closest for me..... I found another Napa part number for fuel line repair kits... I have to see if it is 5/16 or 3/8 kit..... I am pretty sure it is 5/16 kit.....
So far the Napa part numbers for just orings is:
Napa 730-5018 3/8 Viton individual orings $1.56 each
Napa 730-5017 5/16 Viton individual orings $1.35 each
Napa CRB 212305 fuel line repair kit 5/16? $15.93 each
Mopar repair kits:
83502745 fuel line repair kit 5/16 $6.99 Morris
83504447 fuel line/Trans line repair kit 3/8 $8.99 Morris
Ebay sellers are $20.00 and up shipped for these kits.....
Morris 4x4 has the best prices.... all depends on shipping costs.....
http://www.jeep4x4center.com/fuel-oi...-83502745.html
In a pinch local box stores, AutoZone,Orielly:
Dorman 800-016 fuel line clips assorted 5/16 3/8 $5.99
Dorman 800-013 viton orings assorted 5/16 3/8 $5.99
and other stores local might have the Standard/SMP HK7 fuel line repair kit.
$12.00 to $20.00 bucks.......
These are interesting also, could use these as they have fresh orings etc and use bulk Fuel Injection hose to replace the aging fuel pressure hoses.......
http://www.oreillyauto.com/site/c/de...1650&ppt=C0290
Old June 26th, 2012, 01:32
djgrayxj djgrayxj is offline
Note from DJ
Thanks for the update
Old March 18th, 2014, 22:16
kpeeks kpeeks is offline
Sorry to dredge up an old post, but I'm having the same issue. Bought the oring kit from the dealer ($27.50!!!). Think the link should be put in the FAQ!
Plus mine is still leaking. Actually worse than before. Guess I'm gonna pull them back out & try again.
Old March 19th, 2014, 05:00
cruiser54's Avatar
cruiser54 cruiser54 is offline
Gotta have the spacer between the o-rings. Lube the o-rings with motor oil.
Old October 14th, 2020, 02:20
stefanoquinto's Avatar
stefanoquinto stefanoquinto is offline
Hi, I've buy a injector seal kit for my '90 xj limited renix
I've buy the right part?
Remember that I live in Italy, and autozone, napa, advance autoparts don't exist....
I have also a litte movie about the leak but I don't know how post.
Thanks to all and excuse me for bad english
Old October 14th, 2020, 02:21
I've try to post a pic link,but don't appear
Old October 14th, 2020, 05:39
cruiser54's Avatar
The parts you need are also used on General Motors cars. Maybe that helps.
Can a local Fiat dealer order Jeep parts by chance?
Fuel disconnects
Quick disconnect part numbers
The Napa part numbers for just o-rings *is:
Napa 730-5018 3/8 Viton individual o-rings
Napa 730-5017 5/16 Viton individual o-rings
*Remember to re-use your old spacer between the 2 new o-rings!!
Dorman 800-750 trans line repair kit 3/8
Mopar repair kits:
Old October 14th, 2020, 06:08
Thanks for reply, but our local fiat dealer don't sell parts for old jeep....
Old October 14th, 2020, 06:18
cruiser54's Avatar
Go look at your thread on Cherokee Forum that I responded to.
Old October 15th, 2020, 14:34
89Mock 89Mock is offline
What is this "spacer" you speak of and is it located at the fuel pressure regulator? I had to put an O ring in mine to stop it from leaking and just guessed on the size.
Old October 15th, 2020, 15:04
cruiser54's Avatar
What about the o-ring's compatability with gas?
There are 2 o-rings in there, separated by a white spacer.
Old October 17th, 2020, 06:54
Is the spacer the white plastic quick disconnect?
The O Ring said itís compatible with all fuel types. Itís from the big multiple sized pack that Harbor Freight sells.
Fuel line question Onetype OEM Tech Discussion 4 July 20th, 2010 15:55
fuel line o-ring question wildcat-xj OEM Tech Discussion 6 January 4th, 2010 17:55
O Ring in Quick Connect Fuel Line to Manifold? okcjeeper OEM Tech Discussion 10 August 2nd, 2009 19:21
fuel line quick disco o-ring seal part number naughty_auty OEM Tech Discussion 7 June 3rd, 2008 15:33
Fuel line o-ring kit BingBing OEM Tech Discussion 11 October 23rd, 2005 17:56
