Old March 14th, 2018, 04:59
jonb8's Avatar
jonb8 jonb8 is offline
JK D44 swap
Finally had time to swap a set of D44 Rubicon axles under my xj, The axles are out of a 2016 JK with 8,000 miles my buddy swapped out for a set of Rock Jock 70's.. I went with Artec trusses and Ruff Stuff perches and U bolts...
Old March 14th, 2018, 06:37
SlowXj SlowXj is offline
JK D44 swap
Did you have to do anything with the breaking? Stock master push the bigger calipers fine?
Sent from my SM-G900R4 using Tapatalk
Old March 14th, 2018, 06:41
RCP Phx RCP Phx is offline
Re: JK D44 swap
Those axles are known for breaking! Now as far as "braking" goes, it would depend on what year MC he's running now!
Old March 14th, 2018, 08:27
jonb8's Avatar
Re: JK D44 swap
RPC Phx where are these axles "known" to "break" at? Passenger axle tube? So since your so wise what is a big enough axle to hold up to a 35 radial tire on a DD, if a HP D44, trussed and sleeved isn't enough? LOL your such a tool....What are you running under your rig?
Old March 14th, 2018, 08:30
jonb8's Avatar
Re: JK D44 swap
I haven't drove it yet but I'll post up when I do and tell you what I find out. Worse case I'll have to swap out the proportioning valve to a grand cherokee that came factory with rear disks... With 35in tires the rear bias should be ok and feel good....
Old March 14th, 2018, 08:37
JK D44 swap
Much appreciated. I would love to do this swap as that's the width an xj should have been from the factory
Old March 14th, 2018, 09:30
Re: JK D44 swap
That was a factitious comment on "breaking", your good to go with your project!
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 07:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 22:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 08:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 12:40
